SDA-1C Side Panel Removal
thsmith
thsmith Posts: 6,082
edited March 2009 in Vintage Speakers
I have search and found these 2 postings. But wondering if there is any updated information and other considerations on removing the side panels without tearing them up and any other tips on re-attaching?
I want to re-use the side panel cloth as it is original and in great shape. Just need to reglue the fabric to the cover and panels to speakers.
http://www.polkaudio.com/forums/showthread.php?t=26036
http://www.polkaudio.com/forums/showthread.php?t=50156
Post edited by thsmith on
  • Emlyn
    Emlyn Posts: 4,535
    edited March 2009
    The panels are glued on to the sides of SDA-1C's from top to bottom. The panels are wood but are thin and could easily be split if care isn't taken when removing them. They do have a habit of separating from the speakers over time. I got the panels off on mine by very carefully and slowly using a long putty knife. The cloth is glued to the back side of the panel and may also be stuck to the glue on the side of the speaker. Getting the panel removed without damaging the cloth as well is difficult and may not be worth the extra effort. The cloth on mine was stuck in too many places, so I just decided to get the panels off without splitting the panels and put new cloth on afterwards. There will be a lot of old dry glue on the speaker you'll want to remove before you reattach the panels.
    SCompRacer Posts: 8,513
    edited March 2009
    Unlike your situation, I had SRS 2's which needed to be reclothed. They also had glued on side panels. Check out this thread for details. IIRC, I used Liquid Nails to reattach.
  • thsmith
    edited March 2009
    Thanks guys, looks like a long putty knife is the key, and patience
