A Decent used subwoofer
royalty
I have an apartment so I'm not looking to blow the roof. I just am looking for a decent subwoofer used that someone needs to get rid of in the price range of 100 to 150 dollars
HOME AUDIO:
Electronics:
HK 354
Front Power: CARVER TFM-35
Center Power: Audiosource Amp One
Speakers:
Center: CSi5
Fronts: rti10s
Rears: monitor 50s
psw 125 + psw 505 = BOOM
CAR AUDIO
Infinity 6032CF's all around
Electronics:
HK 354
Speakers:
Center: CSi5
Fronts: rti10s
Rears: monitor 50s
CAR AUDIO
Post edited by royalty on
location?Computer room Hegeman 1 SpeakersM&K VX-80 subKenwood DP-7010Cambridge Audio CXC Transport Rega DACPrimaLuna Prologue Four AmpAric Audio Tube PreampGarage Jennings Research SquareCustom tube preampCrown XLS-1000Denon DCD-1500II Modded MSB Link DAC
Iowa City, Iowa 52240HOME AUDIO:
Electronics:
HK 354
Speakers:
Center: CSi5
Fronts: rti10s
Rears: monitor 50s
CAR AUDIO
Infinity 6032CF's all around -
rats, a bit far from seattleComputer room Hegeman 1 SpeakersM&K VX-80 subKenwood DP-7010Cambridge Audio CXC Transport Rega DACPrimaLuna Prologue Four AmpAric Audio Tube PreampGarage Jennings Research SquareCustom tube preampCrown XLS-1000Denon DCD-1500II Modded MSB Link DAC
Why don't you buy 2 X PSW 10s available on polk ebay site for 79 dollars each. Buy two and you'll have 100 Watts/RMS, 200W peak. They are not a great sub, but a GOOD Match for the M50s?
cnh
cnh, the reason I dont want the PSW10's is because I have heard that when there are explosions in movies, there is a great amount of port noise out of these subs. I want a sub that is loud, and can handle the boom alright. My apartments small so it doesnt have to blow the rood off, just handle the lows. Anyway, the shipping for BOTH of those subs would be outrageous. I have thought about this route already. Thanks for the help though.HOME AUDIO:
Electronics:
HK 354
Speakers:
Center: CSi5
Fronts: rti10s
Rears: monitor 50s
CAR AUDIO
starkiller, what do you have in seattle? SUB?HOME AUDIO:
Electronics:
HK 354
Speakers:
Center: CSi5
Fronts: rti10s
Rears: monitor 50s
CAR AUDIO
If you go that way stack them in a corner or put one on either side of LP. That way you can feel them without having to blow the roof off.Speakers: SDA-1C (most all the goodies)
You're right, the problem of port noise has been documented with these. But that can be mitigated a lot by adjusting volume setting and by appropriate placement. I've fooled around with the PSW12 in the past and found that I could more or less reduce the port noise to fairly unnoticeable levels, by positioning the sub at right angles to the main speakers. Port noise comes from the fact that these speakers do not like to be driven too hard.
I'd also check lower priced subs on www.onecall.com I got my present Boston sub there for about 200 dollars--shipping included? A 500 dollar MSRP item?
If your open to a used sub,give Audiogon a try.Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
M&K MX-70 Sub for Music
Odyssey Mono-Blocs
SVS Ultra-13 Gloss Black:D -
Ive looked and they really are not in my price rangeHOME AUDIO:
Electronics:
HK 354
Speakers:
Center: CSi5
Fronts: rti10s
Rears: monitor 50s
CAR AUDIO
yeah, m&k vx-7 powered sub..pretty decentComputer room Hegeman 1 SpeakersM&K VX-80 subKenwood DP-7010Cambridge Audio CXC Transport Rega DACPrimaLuna Prologue Four AmpAric Audio Tube PreampGarage Jennings Research SquareCustom tube preampCrown XLS-1000Denon DCD-1500II Modded MSB Link DAC
Suggest BIC-100 as its pretty decent sub. Close to your budget, but over by a tad.Shoot the jumper.....................BALLIN.............!!!!!
Thanks everyone for the suggestions....I have some work to do!HOME AUDIO:
Electronics:
HK 354
Speakers:
Center: CSi5
Fronts: rti10s
Rears: monitor 50s
CAR AUDIO
Just a suggestion royalty. I use one of these Yammie subs in my HT and it really delivers. I've owned it for 2+ years now and it's a solid performer. My room is roughly 15x20. It's more than adequate bass, well built and well within your price range.
Links:
http://www.amazon.com/Yamaha-YST-SW216BL-Advanced-Front-Firing-Subwoofer/dp/tech-data/B000FJ89UO/ref=de_a_smtd
http://cgi.ebay.com/YST-SW216-YAMAHA-10-ACTIVE-SUBWOOFER-YSTSW216-NEW_W0QQitemZ250360446681QQcmdZViewItemQQptZSpeakers_Subwoofers?hash=item250360446681&_trksid=p3286.c0.m14&_trkparms=72%3A1205|66%3A2|65%3A12|39%3A1|240%3A1318|301%3A1|293%3A1|294%3A50
Free ship on ebay.
That sub is 87 dollars on amazon! My room isnt even 15x20, I am probably going to go with that sub. Hey if it doesnt put out the bass I want I could buy two with those prices.HOME AUDIO:
Electronics:
HK 354
Speakers:
Center: CSi5
Fronts: rti10s
Rears: monitor 50s
CAR AUDIO
yea amazon prices are really great, plus you might get further discounts by checking out deal forums for discount vouchers
Yeah I am really thinking about itHOME AUDIO:
Electronics:
HK 354
Speakers:
Center: CSi5
Fronts: rti10s
Rears: monitor 50s
CAR AUDIO
