DIY RCM need quick help from VPI owners
ckphoto
I will be building a record cleaning machine next weekend and have one question. Does the vacuum wand touch the record or is it floating above. I was going to buy the VPI 16.6 suction tube and mount but I am cheap so I think I came up with a good pvc alternative.
Mitsubishi WD-73736
Pioneer Elite SC-05
Xbox 360
Sony PS3 80GB
Velodyne minivee
Rti70s
Csi40
4-Fxi50s
Monster PowerCenter HTS 3600 MKII
Harmony One
Pioneer Elite SC-05
Xbox 360
Sony PS3 80GB
Velodyne minivee
Rti70s
Csi40
4-Fxi50s
Harmony One
Post edited by ckphoto on
Before getting a VPI 16.5 RCM I used a modified shop vac wand. The flat, rectangular, long wand that you can buy for a small shop vac, plug the end, cut a slot down the center, put two strips of stick-on velvet strips from the craft store, then use a small file to keep filing out the end of the slot until you get the suction just right, and it works pretty good. Getting the suction right is the trick, otherwise the wand will stick to the LP with so much suction you can't move it and will scuff the LP.DKG999
Music System: Magnepan 1.6QR, SVS SB12+, ARC pre, Parasound HCA1500 vertically bi-amped, Jolida CDP, Pro-Ject RM5.1SE TT, Pro-Ject TubeBox SE phono pre, SBT, PS Audio DLIII DAC -
Thanks for the help dkg999 I will post some photos in the DIY section when finished.Mitsubishi WD-73736
Pioneer Elite SC-05
Xbox 360
Sony PS3 80GB
Velodyne minivee
Rti70s
Csi40
4-Fxi50s
Harmony One -
I stated my DIY project this weekend and I used the same approach. I first was trying to hold the creavass tool on the album and it about wore me out. Now I let the vac do the job and it is much easier.
BTW, I have a pint of Triton X-114 if anyone needs some. I use 8 drops per gallon. Most of the 37 albums I cleaned this weekend are almost as quiet as a CD.Speakers: SDA-1C (most all the goodies)
