speakers stuck to stands
sophie
i need to move my speakers in the the next hour and i just picked one up and the stands i built for them are stuck to the bottoms. i painted them with spray paint and let them dry under a heat lamp for around 4 days. could this be the reason for them being stuck? it has been around 2 years since i made the stands.
they are monitor 10b's.
any quick help would be great.
Payton
Payton
Polk monitor 10B's and 5 jr's
Adcom gfa 5500 and HK/240
Adcom gtp 400
Adcom gcp 600
MusicHall MMF 2.1 TT
Adcom gtp 400
Adcom gcp 600
Post edited by sophie on
Probably the paint, no quick way that wont damage them that I can think of.
like a bandage on a cut that healed
spray paint takes like a month to fully dry sometimes, and sometimes longer depending on how many coats and how thick. maybe if you sat them in the sun for a while, or just moved them with the stands attached?
Hair Dryer;)
i bent down to look at the edge to see if there was a side that was not stuck so i could try to startpulling that side off, and found that the speakers were lifted off the stand. i had forgotten that somebody had stuck some real thin foam in 4 places of each bottom. i just pulled a little harder and they came off without a problem.
thanks anyway,
PaytonPolk monitor 10B's and 5 jr's
Adcom gtp 400
Adcom gcp 600
MusicHall MMF 2.1 TT -
Good news and watch that spray paint. It can be nasty stuff.
Baseball bat
