Sub/front set-up
I have a PSW650 sub. And a pair of RT55 book shelfs that I use as fronts. The PSW650 isn't hooked up yet. The sub manual says use the "front speaker level out" on my receiver to the the "front speakers in" on the sub. Then wire to the fronts. Should I do that,or stick with the 5.1 out set-up that I use right now(L,R,C,SUR,SUB) My receiver has a LFE out that I use with the sub I use right now. The PSW650 has a LFE "IN",but,do I use it? If I use the "speaker level out" to the PSW650,do I set my fronts to "Large"? Or,stick with a traditional 5.1 speaker set-up? Thanks, JOHN thrillkiller@live.com
POLK SET-UP: $450 from Craigslist (9/10 looks,10/10 sonically)
1. RT55's - fronts
2. CS400i - center
3. RT/fx - surrounds
4. PSW650 - sub
RECEIVER:YAMAHA HTR-6040
CABLES/CONNECTS: all MONSTER
PS; Should I set my CS400i center to "large" since it has a woofer and a mid-range speakers?
Post edited by thrill killer on
  • apphd
    apphd Posts: 1,514
    edited March 2009
    I would set everything to "small" and use the LFE out to the subs LFE and the AVRs bass management. But it can be done as described in the sub manual, typically called "The Polk Way" but then you will need to use the subs filters to blend it with your system.
    Most but not all prefer the LFE approach.
    Welcome to CP
  • thsmith
    thsmith Posts: 6,082
    edited March 2009
    What Apphd said.
    Dang, Apphd, Subs are the only thing I feel good about giiving advise and you always beat me to it.:eek:;)
  • apphd
    apphd Posts: 1,514
    edited March 2009
    thsmith wrote: »
    What Apphd said.
    Life (or lack of) of the unemployed. Hopefully that will end soon, and I won't have so much time to spend here. Not that it's a bad thing, just not what I prefer.
  • wutadumsn23
    wutadumsn23 Posts: 3,702
    edited March 2009
    + 1 for LFE, less hassle and better results IMO.
    HT Rig
    Receiver- Onkyo TX-SR806
    Mains- Polk Audio Monitor 70
    Center- Polk Audio CS2
    Surrounds- Polk Audio TSi 500's :D
    Sub- Polk Audio PSW125
    Blu-Ray- 80 GB PS3
    2 CH rig (in progress)
    It's not that I'm insensitive, I just don't care.. :D
