APC AV H15 question
phipiper10
I just purchased this and plugged it in. I'm not anywhere close to an electrician and was hoping you guys could just chime in.
So voltage seems fine after a few hours at 118 or 119 consistently
With everything on - TV/Receiver/Amp/preamp/cable box about 4.5 amps
Power display shows 510-530VA and 33%
Does all this seam reasonable?
Analog Source: Rega P3-24 Exact 2 w/GT delrin platter & Neo TT-PSU Digital Source: Lumin T2 w/Roon (NUC) DAC: Denafrips Pontus II Phono Preamp: Rega Aria MK3 Preamp: Rogue RP-7 Amp: Pass X150.8 Speakers: Joseph Audio Perspective 2, Audio Physic Tempo Plus Cables: Morrow M4 ICs & Audio Art SC-5 ePlus, Shunyata PCs Misc: Shunyata Hydra Delta D6, VTI rack, GIK acoustic panels
Post edited by phipiper10 on
I would say that it is fine. Mine pulls around 3.8-4 amps, but I probably dont have the system you do. Also, mine reads around 121-123 volts.
Gary -
Thanks,
Its not clear, at least to me what the power display is referring to with the 33%
Is this the capacity of the unit or from the wall or something else?Analog Source: Rega P3-24 Exact 2 w/GT delrin platter & Neo TT-PSU Digital Source: Lumin T2 w/Roon (NUC) DAC: Denafrips Pontus II Phono Preamp: Rega Aria MK3 Preamp: Rogue RP-7 Amp: Pass X150.8 Speakers: Joseph Audio Perspective 2, Audio Physic Tempo Plus Cables: Morrow M4 ICs & Audio Art SC-5 ePlus, Shunyata PCs Misc: Shunyata Hydra Delta D6, VTI rack, GIK acoustic panels -
My guess is it is used amps (draw) versus the 15 amps available from the wall outlet (or the APC box rating (H15). That would be 15/4.5 = 3. You are roughly at 33% of the available current before the breaker trips. The 510 - 530VA range are amps X volts (4.5 X 118/119). Not sure if the display is infinitely variable or just shows preset ranges.Sony 60'' SXRD 1080p
Amp = Carver AV-705THX 5-Channel
Processor = NAD T747
Panasonic BD35 Blu-Ray
Main = SDA-1C Studio with RD0s, spikes, XO rebuild, rings, I/C upgrade
Center=Polk CS10, Surround = Athena Dipoles, Sub= Boston 12HO
Music/Video Streaming = Netgear NEO550
TT = Audio Technica -
I have the J-10 unit; the 33% is the max capacity of the unit. Crank it up and watch the percentage in use go up...TNRabbit
NO Polk Audio Equipment :eek:
Sunfire TG-IV
Ashly 1001 Active Crossover
Rane PEQ-15 Parametric Equalizers x 2
Sunfire Cinema Grand Signature Seven
Carver AL-III Speakers
Klipsch RT-12d Subwoofer -
hmm do i have placebo affect from this unit or maybe its just the beer!Analog Source: Rega P3-24 Exact 2 w/GT delrin platter & Neo TT-PSU Digital Source: Lumin T2 w/Roon (NUC) DAC: Denafrips Pontus II Phono Preamp: Rega Aria MK3 Preamp: Rogue RP-7 Amp: Pass X150.8 Speakers: Joseph Audio Perspective 2, Audio Physic Tempo Plus Cables: Morrow M4 ICs & Audio Art SC-5 ePlus, Shunyata PCs Misc: Shunyata Hydra Delta D6, VTI rack, GIK acoustic panels
phipiper10 wrote: »hmm do i have placebo affect from this unit or maybe its just the beer!
The sound might be improved with this unit in place. When I added a Panamax M5300-EX into my HT the noise floor was much lower, and there was a "sparkle" that I didn't hear before. It also got rid of annoying buzz that was occurring. I attribute this to the clean power that it delivered versus the nasty 125v that comes into the house.
Moving the Panamax into the 2 channel system and installing an H15 into the HT didn't seem to change anything and I think it will protect the components a little better since it's trimming the voltage a bit.
