bi-amping new RTI-6's
dale442
dale442 Posts: 40
edited March 2009 in Speakers
I recently picked up 4 RTI-6's that are replacing RTI-4's.
I also have changed to a Denon 1708 A\V which is capable of using the surround back channels to bi-amp the front channel 6's. This is a 75w\channel receiver.
Since this system is used for 99.9% home theater only (I have my tfm-45 and SDA-2b's in the same room, two channel only) do you all think that I would get substantial gains by bi-amping only the front channels??
What differences would I hear in home theatre?
TIA,
Dale
Polk SDA 2B's
Carver TFM-45
Sony X33ES
Theater:
Sony XBR-850b
Denon 1709
Rti-6 by 4
Csi 3
Paradigm PSW10
Post edited by dale442 on
  • BjornB17
    BjornB17 Posts: 752
    edited March 2009
    dale442 wrote: »
    TIA,
    Dale
    You probably wouldn't notice a difference with a speaker as small as the RTi-6 but it might be worth a shot. Having the receiver send a separate signal to the tweeter might improve separation a bit but who knows. Definately worth a shot. I bi-amped my RTi10's and to me they sound better, perhaps you can get same results with the 6's. The main reason i bi-amp is to increase maximum power availible to speakers. That wouldnt really be necessary with the 6's since the tweeter alone hardly takes any power.
    KEF Q150 | Rythmik F12 | Yamaha Aventage RX-A780
  • williamgauci
    williamgauci Posts: 88
    edited March 2009
    I've had mine wired up for a few months, not sure how much difference it makes as I have done a direct comparision, but for the length of wire it'll take it can't hurt and I think it has improved the seperation and sound stage a little.
    _____________________________________________
    Yamaha 6080 Emotiva XPA-5 CSi A6 RTiA-7's RTi A1's Velodyne DLS-4000R
  • renowilliams
    renowilliams Posts: 920
    edited March 2009
    Not trying to jack the thread but I have a Yamaha RX-V861 and I am considering bi-amping my fronts RTIA5's. I was reading my reciever manual this morning and see the it can be done within my reciever. I take it willi that you did it this way, as you also have a yamaha reciever. I guess I'm wonderring if my A5's can be bi-amped and I'm also concerned with the speaker crossover. Do I set the reciever to send different frequecys to the speaker??
    "They're always talking about my drinking, but never mention my thirst" Oscar Wilde
    Pre-Amp: Anthem AVM 20
    Amp: Carver TFM-35
    Amp: Rotel RB-870BX
    Fronts : SDA 1B w/ RDO-194s
    T.V.:Plasma TC-P54G25
    Bluray: Oppo BDP-93
    Speaker Cables: MIT Terminater
    Interconnect Cables:DH Labs Silver Sonic BL-1isonic
  • williamgauci
    edited March 2009
    You don't really set anything on the crossover, doing it like this really isn't true bi-amping from what I have read. Really, all you're doing is using the extra set of terminals from the rear channel and sending it to your tweeters. I am assuming that there is some sort of crossover on the receiver when the bi-amp function is set in the setup menu. Just make sure that you follow the instruction manual wiring diagram to ensure your putting the right wires to the top and bottom posts on the speaker. The only crossover setting will still be just for your sub.
    If I remember reading correctly, I think all we're doing by hooking them up this way is moving the jumper from the back of the speaker to the internal wiring of the receiver, which is why there's no real crossover setting for this type of connection and it's not a true bi-amp connection.
  • comfortablycurt
    comfortablycurt Posts: 6,745
    edited March 2009
    There isn't a crossover separation between the two pairs going to the speakers. The crossover points are taken care of within the speaker. The AVR is sending the exact same signal out of both the front channels and the surround back channels.
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
  • silversubaru
    silversubaru Posts: 42
    edited March 2009
    And just to add..... With my set up of 705 receiver with front RTi8's, the bi-amp option had made an audible difference and if your wife can hear the difference, trust me, its a difference:D
  • renowilliams
    edited March 2009
    Thanks for the information guys. I just wanted to get some imput before I do this.
    Amp: Carver TFM-35
    Amp: Rotel RB-870BX
    Bluray: Oppo BDP-93
