CSi5 question
bruss
bruss Posts: 1,039
edited September 2010 in Speakers
I want to get more power to my CSi5.
Thinking of adding another GFA-555II into my rig for it.. Is it better to split the input and use each channel or just bridge the amp? Opinions?
Post edited by bruss on
  • 2-tall
    2-tall Posts: 98
    edited March 2009
    Took one of my Carver tfm24's and tried this.I used a Y sub woofer cable from my center output to the right and left input on the carver.I ran left out speaker to the upper input on the csi5 pulled the jumper and ran the right out to the lower inputs.I found the sound to be more defined and the dialog much clearer.
  • Eusebio
    Eusebio Posts: 16
    reviving this old thread i found in a google search
    isn't what 2-tall is doing just passive "bi-amping" instead just using 2 channels from 1 amp. does this really send more power to the speaker?
