how to get out of protect mode on 787
dmamsa
dmamsa Posts: 80
edited December 2009 in Electronics
While rewiring my HT yesterday my onkyo went into protect mode....any idea how to get out of the protect mode.
The protection circuitry was activated and the manual says to call customer service but I cant wait till tuesday :(
help appreciated.
Lsi9s front
LsiC center
artison surrounds and surround back
Panny XP30 DVD player
HD-DVD - Toshiba HD-A1
B&K 507
SVS CS Ultra (powered by samson 1000)
Pioneer 503CMX plasma
Panny PT-AE900U proector
Lumagen HDQ video processor
Monster HTS 5100
Dish Network VIP211
Post edited by dmamsa on
    F1nut Posts: 51,798
    edited February 2003
    I don't know for sure, but try unplugging it for awhile. Maybe it will reset.
    BTW, it's always a good idea to unplug gear when fooling around with them.
  • goingganzo
    goingganzo Posts: 2,793
    unplug all speakers and check for short in runs. then re atach the speaker wire and turn on and plug in.
  • Ceruleance
    Ceruleance Posts: 991
    This is bad news, but everyones suggestions have been correct, leaving it off, and then trying it without anything plugged into it are good solutions. If they don't work then you probably blew something up when you touched two wires together and shorted it, in this case I hope you are still under warranty and can wait a month to get it back..
  • scottvamp
    scottvamp Posts: 3,277
    Wow - I never put mine into protect mode. Love my 787 though.
    #1 RULE:
    Always power down your reciever completly, when rewiring.
    Call Onkyo!!!!!!!!!!
    Then let me know what they say incase it happens to me.
  • cruiser3
    cruiser3 Posts: 47
    Check your manual and see if there is a re-set proceedure. I have the 696 and there is a re-set proceedure for the micro processor which resets to the default. Try that, and if it doesnt work CALL OINK! Good luck!
    Onkyo 696 receiver, Panasonic DVD RV31U,Polk RM6600 w/ 350 sub (rti28's 2nd zone), JVC Dual tape deck, MMF-2.1 Turntable, JVC 5010 CD R. ((its simple, its cheap, it works))
  • dmamsa
    dmamsa Posts: 80
    Thanks for all the replies...
    I had one of my VCR RCA pluged into a mutichannel output :)
    I rewired the VCR connection and it came back to life.
    thanks for all your help
    Lsi9s front
    LsiC center
    B&K 507
    Monster HTS 5100
    Dish Network VIP211
  • scottvamp
    Glad it worked out. But the way it was worded it has NO power and apparently that wasn't the issue. It WAS not in protect mode.
  • dmamsa
    dmamsa Posts: 80
    scottamp;
    Sorry if my wording was incorrect....when the VCR was plugged in the mutichannel output, the receiver would power on for couple of seconds and they shut off. When I tried to power it up again..the display said PROTECT and it shut off after 2 seconds.
    Lsi9s front
    LsiC center
    B&K 507
    Monster HTS 5100
    Dish Network VIP211
  • Serendipity
    Serendipity Posts: 6,975
    scottvamp wrote: »
    #1 RULE:
    I just finished installing some Zone 2 speakers and my Onkyo did this. The unit was powered off when wiring, and there were no short circuits.
    I think one of the relays in the unit may be going bad. It's not the first time it went into protect mode, but it came right back alive after resetting and powering off/on without messing with the speaker wires (which verifies that there were no short circuits).
    If anyone has this problem, it's a good idea to hold Video 1 + Power and it should reset like mine.
    polkaudio RT35 Bookshelves
    polkaudio 255c-RT Inwalls
    polkaudio DSWPro550WI
    polkaudio XRT12 XM Tuner
    polkaudio RM6750 5.1
    Front projection, 2 channel, car audio... life is good!
  • henson
    henson Posts: 7
    I'd go with what everyone else said. Unplug. Good luck.
