Garage Systems
PSOVLSK
PSOVLSK Posts: 5,381
edited March 2009 in Speakers
Just hooked up an old Kenwood system in the garage, but I'm a little concerned about dust, moisture, extreme temperatures, etc. I currently have the system covered up with a towel (when it's not in use of course), but is there something else I should consider...or do I even need to worry about covering it at all?
Post edited by PSOVLSK on
  • joeparaski
    joeparaski Posts: 1,865
    edited March 2009
    It's an old Kenwood, it is meant to be in the garage.
    Joe
    Amplifiers: 1-SAE Mark IV, 4-SAE 2400, 1-SAE 2500, 2-SAE 2600, 1-Buttkicker BKA 1000N w/2-tactile transducers. Sources: Sony BDP CX7000es, Sony CX300/CX400/CX450/CX455, SAE 8000 tuner, Akai 4000D R2R, Technics 1100A TT, Epson 8500UB with Carada 100". Speakers:Polk SDA SRS, 3.1TL, FXi5, FXi3, 2-SVS 20-29, Yamaha, SVS center sub. Power:2-Monster HTS3500, Furman M-8D & RR16 Plus. 2-SAE 4000 X-overs, SAE 5000a noise reduction, MSB Link DAC III, MSB Powerbase, Behringer 2496, Monarchy DIP 24/96.
  • Conradicles
    Conradicles Posts: 6,343
    edited March 2009
    I have had various systems in my garage for about 5 years and never once had any problems except for horrible acoustics. Mine is insulated though, and new doors that are tightly sealed. I guess it depends on where you live.
    Nothing beats a Man Garage!!!
  • zarrdoss
    zarrdoss Posts: 2,562
    edited March 2009
    Dust is real bad we have alot of dust at my work and despite our best efforts a cd lasts only like 6 months, as far as moisture it depends on where you live, here in CO its dry moderate to cold so not to bad but Dallas humid and hot not good had a receiver in my garage die in two week there.
  • PSOVLSK
    edited March 2009
    joeparaski wrote: »
    Joe
    ROTFL:D:D True, but I'd like for it to live as long as possible. As zarrdoss mentioned, the Dallas humidity is what really worries me.
