RTi70 repiar
polkyson
polkyson Posts: 8
edited March 2009 in DIY, Mods & Tweaks
Hi all. I am new to the forum and need some ideas on how to repair one of my RTi70 speakers. First of all moving is a pain in the butt! Especially when you injure one of your babies! I have a blemish in the wood vinyl on the left top corner and I was wondering if there were any vinyl refinishing kits that could fix it. I can post some pics if it would help. Also one of the bases was damaged. I have ordered a replacement but its seems that the MDF on the bottom of the cabinet where the foot attaches to was damaged as well. How would be a good way to loosen the glue and remove that piece so I can put a new fabricated piece a friend will be making for me in? I don't want to damage the outer 4 sides of the speaker while trying to remove the piece. Once I get it out I can glue, clamp and seal it up easily enough. I just don't know the best way to break it loose. Any help would be greatly appreciated! I love these RTi70's and am not emotionally ready to part with them yet :(
Thanks!!
RTi70 x2
CSi40 x1
RTi38 x4
PSW404 and JBL subs
