What brand is this speak...Scottvamp?
Good luck!:D let's see how well you know your speakers.......
dc.
dc.
Post edited by SPEAKER7 on
Looks like paradigmHome Speakers polkaudio RTi70's (bi-wired), CSi30, FX3000i, PSW250
Car speakers polkaudio EX 369, DB 650 -
Originally posted by ChrisDurano
Looks like paradigm
thats what im thinking...Damn you all, damn you all to hell.......
I promised myself
Damn you all! - ATC -
It's not p-dime, what IS it?Check your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service.
Congratulations too all! Stereo/audiophile experts!
You all have hit the bulleyes ......they are the Paradigms "Signature line"....... suppose to upmarket the Reference line but are still in the development phase and will be priced around 10,000.00 cdn.
I have to try harder next time............
dc.
:supermad: -
speaker 7 what gave it way was the gold driver then all black driversDamn you all, damn you all to hell.......
I promised myself
So what......do I get a pair for guessing right?:DHome Speakers polkaudio RTi70's (bi-wired), CSi30, FX3000i, PSW250
Maybe, just maybe it was the paradigm logo in the background that gave it away."Its worked so far but we're not out yet."
"Hey big man let me hold a dollar" -
yes,
you win a pair of Bose computer speakers!!!! hee! hee! -
I was out - that was my guess also.
Try this one out:SPECIFICATIONS
Overall System
Frequency Range: 16 Hz to 45 kHz Transducers: 46
Output: 120 dB from 20 Hz to 20,000 Hz Amplifiers: Four channels required, up to eight channels may be used
Total magnet weight: 110 LB MSRP: $120,000 system
Main Tower
Frequency range: 40 Hz to 45 kHz Sensitivity: 90 dB @ 2.82 volts
Impedance: 8 ohm / 7 ohm minimum Connection: 3 pair solid copper 5 way binding posts for tri-wire
Maximum Power: 700 watts per channel program Dimensions: 12 inches wide, 84 inches high, 16 inches deep
Weight: 300 LB Finish: Matched Select Santos Rosewood. Std. Other finishes optional
Subwoofer Tower
Frequency Range: 16 Hz to 40 Hz, controlled by Variable Low Pass Filter Sensitivity: 99 dB @ 2.82 volts
Impedance: 1 Ohm minimum Maximum Power: 1000 watts per channel program
Connection: 1 pair solid copper 5 way binding posts Dimensions: 13 inches wide, 84 inches high, 26 inches deep
Weight: 300 LB Finish: Matches Main Tower -
isnt that infinity?Damn you all, damn you all to hell.......
I promised myself
Al"The only way to get rid of a temptation is to yield to it."
I have no idea but they sure look huge and very expensive.........(some of the mid drivers look something like the Dynaudio).
dc. -
Originally posted by jrausch
Al
