Speaker Frequency Range
rlecuyer
rlecuyer Posts: 3
edited March 2009 in Speakers
I am looking to use a test speaker for my power amp. I was wondering: if I use a speaker with a frequency range of say 100Hz-4000Hz, and I give the speaker an amplified signal that ranges from 20Hz-20,000Hz will it see any damage? Or do I NEED to incorporate a crossover just for testing purposes?
Post edited by rlecuyer on
  • Face
    Face Posts: 14,340
    edited March 2009
    How much wattage are you talking about?
    You'll be fine as long as you keep the power low.
    mhardy6647 Posts: 34,934
    edited March 2009
    Should be fine within the physical limits of the test speaker.
    Where you need to be careful is driving, e.g., a tweeter with a wide-range test signal. Significant signal level at a frequency near the driver's Fs (resonance) can be deadly. Actually (and many will disagree, and be theoretically correct) one may carefully test a tweeter with a wide-band test signal, but only at very low level (input voltage) and very carefully. If I were testing an expensive or irreplaceable HF driver, I'd throw a cap in series with the test signal to ensure LF is kept away from the driver.
    HTH (as they say).
