Help with Lsi25
raidersrule76
raidersrule76 Posts: 471
edited March 2009 in Speakers
Last night the power went out a couple times and the last time it did it there was a loud pop from the right channel and now the sub dosent seem to work the light is on for the amp on the back of the speaker but no bass. It was working fine before that so I dont know what happened. I do have everything plugged into a power conditioner. Any help would be appricated.
Sig to be updated after dealing with the insurance company:(:(:(
Post edited by raidersrule76 on
  • steveinaz
    steveinaz Posts: 19,538
    edited March 2009
    Click the support tab above, let them know you are a forum member. Polk CS is excellent.
  • Mike21
    Mike21 Posts: 252
    edited March 2009
    It sounds like your Monster 3600 failed to protect ypour sub. I'm pretty sure Monster Inc has some kind of warranty covering this.
    In the event of a power spike or surge, the Monster's fuse module is supposed to shut everything dowm before the spike has a chance to reach anything that is plugged into the Monster. After that, the Monster won't work until you get the module replaced, which Moster Inc is supposed to do for free.
    Mike
    ____________________________________________
    Home Theater 32"LG LCD; Comcast; 7.1 Onkyo 805; Fronts: Polk M50s; Center: Polk CS2; Sides: Polk M40s; Rear: B&W LM1s; Subs: (2) Sony 12" x 100w; Samsung 1500BDP; Toshiba A-2 HD-DVDP.
    PC stereo: Viper custom PC: Windows XP; ASIO4ALL; JRiver Jukebox> Pop Pulse USB to S/PDIF conv> Monarchy DIP > Musiland MD10 DAC > Parasound 2100 pre> Aragon 4004 MKII amp> Dali Ikon6 towers; Sunfire True Sub; PSA Duet, Ultimate outlet and Noise Harvestors.
  • raidersrule76
    edited March 2009
    wouldn't the light on the front of the monster show that there is a problem? Everything seems to be the same as it was.
  • raidersrule76
    edited March 2009
    WOW what great CS!!!!! Just recieved an email from Kim in CS and they said to send my address and they would send me a new amp. I hope that this is the problem and all is good. Thanks for the help guys.
    Best regards,
    mark
  • steveinaz
    edited March 2009
    Good deal, I knew they would hook you up.
