Dual Sub setup help.
Govnah
I have two PSW150s and been reading here it it best advised to stack the subs on top of one athother or place them in the left and right corners. Newb here so any help I would appreciate.
Post edited by Govnah on
If you have access to a SPL meter and a CD burner, you can run a frequency response sweep for both configurations and see which one gives you the flattest FR with the least amount of room cancellation modes.
Corner placement excites more room modes than any other, resulting is less nulls in the listening area. I recommend stacking in the same corner - you will get 6 dB more bass headroom, and avoid the potential problem of competing bass waves from subs in two different parts of the room, which can create standing waves with big peaks and nulls."What we do in life echoes in eternity"
Ed Mullen ([email protected])
SVS
