db1212 amp..?
nhlhitz23
hi everyone, I was planning on purchasing the dB1212. It says use Class-D.
The sub can: power handling: 50-360 watts RMS (720 watts peak power)
So I am guessing to get a 700watt amp or lower..?
Also any recommendations on what amp? (polk, pioneer, alpine)
Sorry I am a little new around car electronics, just trying to learn more.
Post edited by nhlhitz23 on
What's your budgetExpert Moron Extraordinaire
polkPolk MM6501 kick panels, Eclipse cd7200mkll and SW9122 Bomb Box, Cadence A4, A7, CAP5, JL8W3V3
yeah polk have some nice reviews, my budget for an amp would be 400 or less.
Here you go.
http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=20399
Soundstream RUB1.400
400 Watts RMS Mono Block Rubicon Series Subwoofer Amplifier -- $179.
Decent amp, great price, meets your power needs, looks good IMO and it well under your budget leaving you plenty of coin to get yourself some good cabling too.
Like this installation kit: http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=20370
Even comes with a decent RCA patch cable. That's everything you need to stick that amp in your car with those subs and I'll bet you will be more than happy with it.Expert Moron Extraordinaire
Here you go.
hey jstas, thanks for the reply. This helps out a lot.
