Best tube CDP for 1K
bobt
Before I pull the trigger on the Jolidia, Is there any other CDP (tube)I should look into for the 1K price? This is to replace my Sony XA3ES.
Or is there really nothing in the price range that comes close???
Post edited by bobt on
The Jolida is said to be the best tube CDP under $1k. It's my next cdp as well.
Until you start jumping on the Jolida bandwagon,I suggest you try out the Bada HD-22SE.
I just got one and am very pleased with it. At $599 new it's a steal.
Leroy,you should come down to Rockford and get your ears around the Bada. -
Bobt, just out of curiosity what pre-amp are you considering upgrading to? The Adcom GTP-400 is going to be a major bottleneck in your system after you upgrade the CD player. It might even benefit you to upgrade the pre first...Speakers: Polk LSi15
Amp: Pass Labs X-150
CD/DVD Player: Classe CDP-10
TT:Micro Seiki DD-35
Cartridge:Denon DL-160
Phono Pre:PS Audio GCPH -
Yeah the Adcom preamp..is not the best. I would love a AR sp-9 MK3 or a 10...but finding those may be a problem, at least at a 1K price. I could go for maybe a CJ- PV5......but not sure on that.
Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
M&K MX-70 Sub for Music
Odyssey Mono-Blocs
SVS Ultra-13 Gloss Black:D -
You can get a good CD player for about $25 on CL. You don't need to spend 1K. It is just 1's and 0's. They all sound the same. Hell I got a 5 DISC CD CHANGER for about 15 minutes of caulking.:rolleyes:I like speakers that are bigger than a small refrigerator but smaller than a big refrigerator:D
I'm very impressed with the Original CD-A8T. 12AU7 tubes used as buffers.
Dave, may I ask what gear and speakers you have pair with the Bada?2 Ch.
Parasound Halo A23 Amp
Parasound Halo P3 Preamp
Parasound Halo T3 Tuner
Bada HD22SE tube CD Player
Magnum Dynalab Signal Sleuth
Magnum Dynalab ST-2 antenna
polkaudio Lsi9s (upgraded cross-overs)
MIT Shotgun S-3 Bi-wire Interface Speaker Cables
MIT Shotgun S-3 Interconnects (3)
IegO L70530 Power cords (3)
HT
Denon 2808ci AVR
polkaudio RTi A5s (fronts)
polkaudio RTi A1s (rears)
polkaudio Csi A6 (center)
Signal Cable Ultra Speaker Cables
Signal Cable Analog II Interconnects -
Norm, PM sent
I would also like to throw the AH! 4000 (njoeb tjoeb) with the upsampling board upgrade into the mix...
a solid performer , IMOCary SLP-98L F1 DC Pre Amp (Jag Blue)
Parasound HCA-3500
Cary Audio V12 amp (Jag Red)
Jolida JD-100 CDP
SVS PC-Ultra Sub
MIT Shotgun S1 I/C`s
AQ Black Thunder Sub Cables
PS Audio Plus Power Cords
:cool: -
Zero - I bet the Lector is the shiznit but the question was below $1000............
daboyz - I read it as "at" $1000. Still, the used Lector is a tad above the range - but really, the only other solid options I can think of at this level would be a used Naim CD5i or a used Cambridge 840, neither of which are tubed.
You're correct,my bust on the terminology. I guess it's the cheap part of me that always thinks "less than" then "around" the dollar figure. Someday I hope to have the coin to be able to afford a cdp like the Lector.
Tubes definitely rule.
