Polk RTi9's or LSI15's
bdtae5656
bdtae5656 Posts: 235
edited March 2009 in Speakers
Ok...quick question, Im building a home theater system. I've got the TV,a LSIC, and HK AVR354. Will the HK be enough power for the Rti9's or LSi15 until I but a amp? If not what AVR would you recommend thats will support 4ohms or 8. What would be good surround speakers
TV:Sony Bravia XBR4 52'
Mains: Lsi m 705
C:Lsi m 706
Rears: Lsi m 703
Sub: Epik Empire
Pre:Marantz AV 7005
Amp:Sunfire TGA-7400
Blueray: Opp 93
A/V Component: Panamax M5100-PM
Cables: Signal Cable, White Zombie, MIT, Pepster's power cables
Post edited by bdtae5656 on
  • Menasor
    Menasor Posts: 283
    edited March 2009
    It looks like you have a good start. Since you have a LSiC already, I would go with an LSi setup and go with the LSi15, which is an awesome speaker.
    You'll need external amplification. No reasonably priced AVR can handle the LSi's or the RTi A9's anyway. Look at the Emotiva XPA-5 (200wpc x 5). It's very good value for the money. As for the surrounds, I'd go with the LSiFX.
    Fronts: Energy RC-70
    Center: Energy RC-LCR
    Surrounds: Energy Veritas 1.0CM
    Subwoofer: SVS PC12-NSD
    Receiver: Onkyo TX-SR705
    Amplifier: Denon POA-2200 w/ Ben's ICs
    Pics of my setup (click me)
  • bdtae5656
    edited March 2009
    Menasor wrote: »
    Will the 15's be ok w/ my HK for now? At least until I get a amp
    Mains: Lsi m 705
    C:Lsi m 706
    Rears: Lsi m 703
    Sub: Epik Empire
    Pre:Marantz AV 7005
    Blueray: Opp 93
  • Menasor
    Menasor Posts: 283
    edited March 2009
    bdtae5656 wrote: »
    Honestly I don't think so. They're very power hungry. Don't change your AVR because of this though. The AVR354 is a very good receiver
  • bdtae5656
    edited March 2009
    Menasor wrote: »
    Also...what G wire should O be using on the 15's or Rti9's?
    Mains: Lsi m 705
    C:Lsi m 706
    Rears: Lsi m 703
    Sub: Epik Empire
    Pre:Marantz AV 7005
    Blueray: Opp 93
  • Menasor
    Menasor Posts: 283
    edited March 2009
    bdtae5656 wrote: »
    I'd go with a 12 or 14. Take a look at the Belden 12AWG here:
    http://www.bluejeanscable.com/store/speaker/index.htm
    I'm currently using the BJC 12AWG.
  • wizzy
    wizzy Posts: 867
    edited March 2009
    Did you mean RTi9 or LSi9 ??
    Many would say LSi9, and get yourself a separate(s) for the subwoofer part.
  • bdtae5656
    edited March 2009
    wizzy wrote: »
    Separate for the sub?
    Mains: Lsi m 705
    C:Lsi m 706
    Rears: Lsi m 703
    Sub: Epik Empire
    Pre:Marantz AV 7005
    Blueray: Opp 93
  • bdtae5656
    edited March 2009
    Menasor wrote: »
    Menasor,
    is it hard to hook up a amp to the AVR? Do you have to tune it, etc?
    Mains: Lsi m 705
    C:Lsi m 706
    Rears: Lsi m 703
    Sub: Epik Empire
    Pre:Marantz AV 7005
    Blueray: Opp 93
  • curved
    curved Posts: 664
    edited March 2009
    bdtae5656 wrote: »
    Menasor,
    It's extremely easy to hook up. You will have to tune it just like you would with just your AVR. Each speaker has a different sensitivity as amps have a different gain from one another (outside of being the same model). Plus, we'll help you:D
    Living Room:....................[HTML] [/HTML] Zone 2 (Workout Room):
    AVR - Yamaha RX-V757......JBL 4312 Pro Monitors
    Pre - Nak CA-5
    AMP - Adcom 555 (Main)
    Main - Polk RTI8**/RTiA5
    AMP - Adcom 545II (Center)
    Center - Polk CSiA4**
    Sub - Snell Basis 300:p......Zone 3 (Outside)
    CD - Yamaha CDC-555.......Def Tech AW5500
    TV - Pani TH-42PZ80U
    BR - LG BD390
    Monster HTS1600 Power Center
    Dedicated Circuit - (2) 20amp, (1) 15amp
    Ben's IC, Canare 4S11
    **Dayton and Sonicap Caps with Mills Resistors**
  • bdtae5656
    edited March 2009
    curved wrote: »
    Question....Amp to AVR by RCA. AMP to Speaker by Cable wire right? What would happen if I also hooked my speakers up to my AVR? Thats bi-amping correct
    Mains: Lsi m 705
    C:Lsi m 706
    Rears: Lsi m 703
    Sub: Epik Empire
    Pre:Marantz AV 7005
    Blueray: Opp 93
  • curved
    curved Posts: 664
    edited March 2009
    bdtae5656 wrote: »
    AVR to Amp with RCA. Amp to speakers with speaker wire.
    I wouldn't suggest doing that because the amp probably have the same gain as your AVR. The correct way to bi-amp is 2 seperate amps being the same exact model.
    Pre - Nak CA-5
    BR - LG BD390
  • wizzy
    wizzy Posts: 867
    edited March 2009
    bdtae5656 wrote: »
    Yes, the LSi9 is like a LSi15 just chopped off at the top and no woofer. Look at the pictures.
    So if we can ignore all facts we get:
    ( LSi9 + separate subwoofer ) == ( LSi15 with built in subwoofer )
    but the general feeling is you can do better with LSi9 + sub ... or invest the money saved buying the LSi9 over the LSi15 into a subwoofer.
    I'm sure people will argue either way on pluses and minuses.
  • devani
    devani Posts: 1,497
    edited March 2009
    your HK will be fine for moderate listening with LSi15....as long as stay within reasonable level although you will benefit from adding an amp....
    Video: LG 55LN5100/Samsung LNT4065F
    Receiver: HK AVR445
    Source: OPPO BDP-93
    HT: POLK SPEAKERS RTi6, FXi3, CSi5, VTF-3 MK2
    2Ch system: MC2105, AR-XA, AR-2A, AR9, BX-300, OPPO BDP-83
  • leroyjr1
    leroyjr1 Posts: 8,785
    edited March 2009
    You will definately need a external amp for the LSI 15's.
  • maximillian
    maximillian Posts: 2,149
    edited March 2009
    wizzy wrote: »
    The crossover network for the speakers are different. The LSi9's have to handle the more bass than the LSi15's upper portion. The cabinets are also slightly different because of it. The LSi15's do not have a rear power port since it is on the bottom for the woofer.
    In calculating the cost of the LSi9's don't forget to also include a good stand. This is at least $100 for a pair and can be up to $250.
  • bdtae5656
    edited March 2009
    wizzy wrote: »
    How bout teh Rtia9's vs the Lsi15??? So what your saying is that I wont need a sub if I get the 15's?
    Mains: Lsi m 705
    C:Lsi m 706
    Rears: Lsi m 703
    Sub: Epik Empire
    Pre:Marantz AV 7005
    Blueray: Opp 93
  • Ricardo
    Ricardo Posts: 10,636
    edited March 2009
    For Home Theater you will need a sub, period. Very few speakers will give you the slam you need for action packed movies with explosions, etc.
    RTi line is great for HT; if you're also into music, then the LSi line will be a better choice. You already have the LSiC, but if you decide to go with the RTi line you can always sell it.
    You can use your HK receiver temporarily for LSi's, but as someone already said, you need to watch your level or you could damage the speakers (too little power will damage speakers faster than too much power).
    The RTi line requires less power, but if you go with the RTia9, you will also need an external amp to get best out of of all those woofers; the RTiA5 will work fine without one.
    Enjoy the ride.
    SOPA
  • bdtae5656
    edited March 2009
    Ricardo wrote: »
    Enjoy the ride.
    That sounds good! Where is a good place other than ebay to start looking for Rti9's or Lsi15's that wont break the bank?
    Mains: Lsi m 705
    C:Lsi m 706
    Rears: Lsi m 703
    Sub: Epik Empire
    Pre:Marantz AV 7005
    Blueray: Opp 93
    tonyb Posts: 33,067
    edited March 2009
    If it was me,I would go LSI9's with a good sub,not a cheapo sub,a good one that can play nice and tight for music and HT.You still need an amp though.If money is tight,drop down to the RTI line and maybe you can eliminate the amp part.Seems to me you are trying to build a system around a center channel speaker.Take the amount of cash you have budgeted for a system and start over.If that means selling the LSI center,then so be it.You will get more enjoyment from a complete system.
  • bdtae5656
    edited March 2009
    tonyb wrote: »
    Your saying use the Lsi'9's as the L/R
    Mains: Lsi m 705
    C:Lsi m 706
    Rears: Lsi m 703
    Sub: Epik Empire
    Pre:Marantz AV 7005
    Blueray: Opp 93
    tonyb Posts: 33,067
    edited March 2009
    bdtae5656 wrote: »
    Yes sir,since you have the center,the surrounds aren't as important as the front 3 are.Get the 9's,a sub,an amp,and pick up surrounds on the cheap in our flea market,and you'll be happy as a clam,untill you have some coin burning a hole in your pocket that is.
  • wizzy
    wizzy Posts: 867
    edited March 2009
    Fry's has cherry LSi9 on sale now for $699/pair
    You can find a better deal on e*bay, but even from Polk you won't get the five year warranty you get brand new.
    That's probably a bit of $$$ saved over rtia9/lsi15 that you can add to the subwoofer fund - probably enough where you could get a > $1,000 sub
    http://shop1.frys.com/product/3586894
    W
  • danz1906
    danz1906 Posts: 5,144
    edited March 2009
    Although both the RTiA9 and Lsi15 will do Music and Home theater,the Lsi15 will be better for Music:D...RTiA9 better for Home theater:D
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    M&K MX-70 Sub for Music
    Odyssey Mono-Blocs
    SVS Ultra-13 Gloss Black:D
