ADCOM GFA-555 mod
Lowell_M
Lowell_M Posts: 1,660
edited March 2009 in Electronics
Ben or others,
I've only been able to find limited details on the ADCOM mods that are possible. I am trying to understand the shunt capacitor (??) mod a little better to consider if I should give it a shot. :cool:
Skill Level: I have limited experience soldering on a board, but am otherwise perfectly mechanically capable. I used to have a very deep knowledge of electronics, but haven't used it since my senior year in college, so let's consider it almost gone from my brain. But...with some explicit explainations to start with, I'm sure I can ask enough questions to make sure I understand and don't screw things up. :eek::rolleyes:
So... What kind of mods can be easliy done to the GFA-555 and what are the benefits of the mod.
Also... Are the mods easily reversable if I don't like the results?
Thanks:cool:
HT
RTi70 mains
CSi30 center
RTi28 Rears
Velodyne CHT-12
H/K AVR-247
ADCOM GFA-7000
Samsung PN58B860
Playstation 3
2-Channel
Polk Audio LSi15's
Rotel RCD-1072
Nakamichi CA-5 Pre
ADCOM GFA-555
Signal Cable Analog II IC's
Signal Ultra Bi-Wire Speaker Cables
Post edited by Lowell_M on
  • ben62670
    ben62670 Posts: 15,969
    edited March 2009
    From what I have done the mods are simple on the shunt caps on the big caps. Use a 12uf or so cap on top of the main PS caps. An audio grade cap like the Dayton's is fine. Also you may want to add a 1uf cap in the mix. The big caps are designed to hold a lot of currant. If you add smaller caps the detail is slightly better. Also on the input boards are a few fusible resistors that are not the best for signal path. Shoot me a PM, and I can tell you what resistors to replace. I am going to do the mods myself finally on my own amps. GV27 has pointed me in the right direction concerning replacing signal path R's;)
    Ben
  • comfortablycurt
    comfortablycurt Posts: 6,745
    edited March 2009
    I've been curious about this myself. I'm planning on getting an Adcom 555 in the near future, once my HT is rounded out. I've heard a little bit about the mods that people have done to them, but haven't really been able to find any solid info about them either.
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
  • Systems
    Systems Posts: 14,873
    edited March 2009
    I think Ben has a schematic so he can tell you if there are any coupling and feedback caps that may need replacing/upgrading aswell.
    Testing
    Testing
    Testing
  • Ender
    Ender Posts: 603
    edited March 2009
    Ben, could you shoot me an email about the mods as well? I got a GFA-555MKII a few weeks back that I want to mess with. Lol.
    SDA 1C, SDA 2A, SDA SRS 2, CMT-340SE, Swan M200MKII, Swan D1080MKII, Behringer MS40
    Outlaw Audio M2200 x2, GFA 555 II, BGW 750C
    GDA 700, Outlaw Audio Model 990, Sansa Fuze, X-Fi Platinum Fatality
  • ben62670
    edited March 2009
    GV#27 wrote: »
    I have most of the diagrams:)
    Ender wrote: »
    You have my number no? Shoot me an email.
    Take care.
    Ben
    Ben
    heiney9 Posts: 25,409
    edited March 2009
    Also guys.............do a search at DIYAUDIO.com and you will find several long threads on mods for those Adcoms.
  • ben62670
    edited March 2009
    heiney9 wrote: »
    Thats wheere I learned my stuff;) Again a few naughty resistors, and the cap mods can go a long way. I said it before and I will say it again. Thanks H9 for pointing me in the right direction. NP, and Chris have taught me much!
    Ben
    Ben
  • Lowell_M
    edited March 2009
    heiney9 wrote: »
    Thanks!
    HT
    RTi70 mains
    CSi30 center
    RTi28 Rears
    Velodyne CHT-12
    H/K AVR-247
    ADCOM GFA-7000
    Samsung PN58B860
    Playstation 3
    2-Channel
    Polk Audio LSi15's
    Rotel RCD-1072
    Nakamichi CA-5 Pre
    ADCOM GFA-555
