what load would this be...?
Amit1591
What load would it be If i take my 2 Polk SR124dvc's set them both each to 2ohm settings and then connect the two positives and two negatives from each sub together into the amp...what would that result in and is it safe?
Post edited by Amit1591 on
Dodd - Battery Preamp
ADS 1230 - Polk SDA 2B
Crown K1 - Subwoofer amp
Outlaw ICBM - crossover
Beringher BFD - sub eq
"I've always been mad, I know I've been mad, like the most of us have...very hard to explain why you're mad, even if you're not mad..." -
Ok thanks... it would be a 1ohm load.
