Small cracks in MW6500 surrounds
dc55110
After replacing the MW6500 that had a tear in the surround (thanks ND13) I was taking a closer look at the other MW in my Monitor 10As. I noticed very small cracking on the surrounds of two other MWs when the passive radiator was pushed in and the MW were fully extended. Is there something I can do to prevent these slight cracks from becoming tears? Any type of reconditioning?
(((STEREO)))
Sony DVP-N9000es
Squeezebox Duet
Theta ProBasic IIIA
Audio Research SP14
White Audio Labs B1
Transparent SoundWave Super
Paradigm Studio Monitor
B&W 802 s3
HT
Sony Bravia KDL-40Z4100
Sony BDP-S350
Yamaha HTR-5790
NHT SB3 (Fronts)
NHT SC2 (center)
NHT SB2 (surround)
Velodyne FSR12
Sony DVP-N9000es
Squeezebox Duet
Theta ProBasic IIIA
Audio Research SP14
White Audio Labs B1
B&W 802 s3
HT
Sony BDP-S350
Yamaha HTR-5790
NHT SB3 (Fronts)
NHT SC2 (center)
NHT SB2 (surround)
Velodyne FSR12
I would give Polk CS a call and see if they have any experience with this issue. That is definitely something you wouldn't want to get worse. :eek:
I would put a rubber conditioner like a tire care product on them. DO NOT use Armor-All!Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
At this point, no conditioning is going to repair cracks. It will only swell the rubber so you can't see the cracks anymore. The damage is already done. Even rubber will eventually deteriorate with age, albeit much slower than foam surrounds. What are the dates on the drivers?Ludicrous gibs!
I hear mink oil is good for rubber surrounds to keep the rubber conditioned but depending on where you live and the humidity eventually they will go bad.
(((STEREO)))
Sony DVP-N9000es
Squeezebox Duet
Theta ProBasic IIIA
Audio Research SP14
White Audio Labs B1
B&W 802 s3
HT
Sony BDP-S350
Yamaha HTR-5790
NHT SB3 (Fronts)
NHT SC2 (center)
NHT SB2 (surround)
Velodyne FSR12 -
So what you are saying... Play them till they fail, then replace the drivers?(((STEREO)))
Sony DVP-N9000es
Squeezebox Duet
Theta ProBasic IIIA
Audio Research SP14
White Audio Labs B1
B&W 802 s3
HT
Sony BDP-S350
Yamaha HTR-5790
NHT SB3 (Fronts)
NHT SC2 (center)
NHT SB2 (surround)
Velodyne FSR12 -
I would replace them now, those surrounds are about as thick as a baloon and failure is certain. It probably is already affecting the sound quality
29 years old......they owe you nothing. Time to buy some new ones.
Yep, I'd say they're about due for new drivers. Then you can enjoy what are essentially new vintage Polks!Ludicrous gibs!
