everything got "muddy"
heavyismymetal
Just wanted to note something unexpected that I experienced today. Last week I hooked up a pair of RTi70's to my receiver and loved the sound I got even better than the sound room at the store....bi-wired 'em and got an improvement in the highs and the midrange seemed "warmer"...and amazingly to me, these things can actually hold their bass well too! Anyway, I also ordered the PSW350 to compliment the bass duties thinking I would have a nice set-up. Sub was hooked with Monster sub cable to the LFE input......sounded muddy. Unhooked that and tried both the left and right side of the L/R rca inputs.....still sounds muddy. (Better, but still muddy) Obviously, I am thinking of hooking up the line level inputs to the sub next, but I really don't want to miss out on the bi-wire enhancement. And I would like to keep the speaker cable mess down to a minimum.LOL (is that ever acheivable?) The receiver is a JVC RX-992, with a built-in eq.....(a feature that I really don't like, but have learned to deal with) the manual says nothing about hooking up a sub except that if the consumer wishes to hook a sub to the product to buy a seprately puchased sub and hook it up via rca cable....nothing on filtered or unfiltered and there is no way to program a setting of main or small or anything, just a "subwoofer out" jack on the back. After playing various CD's (Van Halen's Balance, Sammy Hagar's UnBoxed, AC/DC's FTATR, etc) the best I could come up with was the sub at a 90 degree angle in the corner behind the left speaker with the mains about 10 feet apart. The sub hooked at the left rca input, not the LFE input....the cross set at the max and the volume at about half to 3/4 . Is there any one that can let me know if there is something that I am missing in getting a "cleaner" sound out of my rig? I am almost considering sending the sub back and just being happy with the RTi70's as a stand alone rig. But then again are we really ever just "happy" with anything? Thanks for the posts.
HT Setup:
Denon DHT-682
Denon sc-70s front/rear
Denon sc-70c center
Polk PSW-202 sub
Music Room Setup:
JVC RX-992 receiver
Polk RTi 70's Bi-Wired
Polk PSW350
The Car Barn:
Aiwa NSX-D30
Denon DHT-682
Denon sc-70c center
Polk PSW-202 sub
Music Room Setup:
JVC RX-992 receiver
Polk PSW350
The Car Barn:
Aiwa NSX-D30
Post edited by heavyismymetal on
Why is your crossover set at full and the volume at 3/4? Unless you have miniscule little 3" satelites, such agressive settings will most likely make everything muddy and bass-heavy. Try lowering Xover and volume a bit and see if it helps.
You don't have to live with it, but try the line-level to see if it makes an improvement.
And if you think the 70s have good bass, then what you would use the sub for is to extend low frequency response, not make it louder. If you have tried every single connection option and you still aren't happy with the 350, then by all means send it back. Then, get a "real" sub - one that extends below 20hz and see if you aren't happier with that.
And also, location is everything - have you tried places other than the corner? Even a movement of a foot or two can make everything "snap" into focus and become clearer.
