what about only doing the crossover rebuild half way?
danger boy
danger boy Posts: 15,722
edited May 2009 in DIY, Mods & Tweaks
ok.. i have had two pairs of Monitor 7B's and 7A's crossover's rebuilt. Each time I have enjoyed the x-over updating. both have had peerless tweeters.
ok, stay with me on this one.. what if I want to have the SDA 2B's crossovers redone, but only half way?? :confused:
meaning, I am very pleased with the RD0-194 tweeters that I'm afraid I would lose their pitch if I had the crossovers rebuilt. so can a crossover be rebuilt and not tough the parts of the crossover that runs the tweeter? anyone ever try this?
I'm just afraid if the wrong part is replaced, i could end up with a shrill sounding tweeter.. that may not tame itself again.. then i'd be very pissed off.
PolkFest 2012, who's going>?
  • Disc Jockey
    Disc Jockey Posts: 1,013
    edited March 2009
    You can rebuild the complete crossovers and still use the 194s, and it will only get better. Definitely not shrill. You can also just do the low pass but that , in my opinion, would only give a small improvement. Your best bet is to do the TL mod and use the 198s. If you don't like it, it's easy enough to reverse.
    "The secret of happiness is freedom. The secret of freedom is courage." Thucydides
    F1nut Posts: 52,346
    edited March 2009
    Do the full TL upgrade. You can thank DJ and I later.
  • Disc Jockey
    edited March 2009
    f1nut wrote: »
    do the full tl upgrade. You can thank dj and i later.
    trust us.... :D
  • danger boy
    edited March 2009
    i don't think my older 2B's qualify for the TL upgrade.. the serial number If I remember right isn't the right ones
    here are my serial numbers. left 15425 and right 15422
    blade/blade cable.
    let me know though.. i'm not displeased with the sound.. but as with a lot of older gear... updating can yield some big improvements :D
    F1nut Posts: 52,346
    edited March 2009
    Al, I believe you are confusing the TL upgrade with the ability to use the AI-1. Your 2B blade/blade crossover uses the same components as the 2B pin/blade, so TL away.
  • Disc Jockey
    edited March 2009
    yep yep. My 2Bs are also blade/blade but the crossovers have the same internals as the pin/blade. Just do it...:cool:
  • Face
    Face Posts: 14,340
    edited March 2009
    Another vote for the TL upgrade, you won't forget it.
  • danger boy
    edited March 2009
    ok.. that is good news then for my 2b's. now i just need to find someone willing to do the work. I don't have the needed skills to do them myself.
  • Face
    Face Posts: 14,340
    edited March 2009
    Face wrote: »
    Another vote for the TL upgrade, you won't regret it.
    Fixed... :rolleyes:
  • MillerLiteScott
    MillerLiteScott Posts: 2,564
    edited March 2009
    TL is the way to go. You will forget about the RDO 194's and love the sound of the RDO 198's.
    Scott
    I like speakers that are bigger than a small refrigerator but smaller than a big refrigerator:D
  • DollarDave
    DollarDave Posts: 2,575
    edited March 2009
    Is there a link to a parts list for the TL upgrade for the varous SDA's? I may break down and do my CRS+'s and use my 194's in my AB-800s.
  • Disc Jockey
    edited March 2009
    I think there is one for the CRS+ specifically. This is one for the 2B's, which use the same crossover.
    http://www.polkaudio.com/forums/showthread.php?t=74945
  • xsmi
    xsmi Posts: 1,812
    edited May 2009
    What is the "TL Upgrade"? I have seen the term from time to time but never paid enough attention to it because I didn't have SDA's now that I am getting SDA-SRS 2's I want to know what it is and if the SRS 2's can have this mod?
    2-channel Yaqin B2-T Pre, Emotiva XPA-2 Gen 2, Marantz SA8005, Pro-Ject RPM-10 Turntable, Denon DP-59L Pro-Ject Phono Box DS3B, Polk Audio Legend L800's, AudioQuest Cable throughout.
