FXi50s placement?
BIGECASTILLO
hello everybody,my question is do the fxi50s have to be right on the wall or can they be about 4 inches from the wall im using banna plugs so i need the extra space just curious thanks for any input
TV WS 65809 MITSUBISHI HDTV REC ONKYO TX-SR800 DVD SR-5700 TOSHIBHA MAIN RTi70s CENTER CSi40 REAR FXi50s BACK REAR FXi30s SUB VELODYNE CHT15
Post edited by BIGECASTILLO on
I don't think 4 inches will make a bit of difference. After all, this isn't golf. I would scrap the bananna plugs and just wire direct. Then you won't have a problem and it will look better.
