Do old tube amps wattage ratings change with speaker load??
faster100
faster100 Posts: 6,124
edited February 2003 in Electronics
I am looking into later this year getting a old tube amp/amps, either a Dynaco 70 or heathkit w-5m Mono amps x2, both rated at 35 wpc and 25 wpc respectivly, I see nothing stating at 8ohms, 4 ohms, I see the heathkit amps have a common speaker lead hookup and 3 others, 4,8,16 ohm... But does the wattage change at said ohms, or what is the rated watts for?? The lowest load 4ohms, or is it the same no matter what on old tubers?? I wanna know, i am hooking them to a set of RTI28's or possibly lsi 7's, neither do i have yet so its open, later this year also will this project for a 2 channel rig take place,
MY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
LSIfx surround backs
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Rotel 1080 stereo amp
Polk sda 2B
kenwood grunt Tuner
realistic lab 450 TT
Signal cable IC
Post edited by faster100 on
  • madmax
    madmax Posts: 12,434
    The wattage stays the same. These different ohm outputs are different windings on the transformer which keep the voltage and current within spec. So you hook up an 8 ohm speaker to the 8 ohm tap. You get a given voltage and current which gives you a certain wattage. (voltage x current = watts). If you hook up a 4 ohm speaker to a 4 ohm tap the voltage and current vary but the voltage x current equals the same wattage.
    madmax
    Vinyl, the final frontier...
  • RuSsMaN
    RuSsMaN Posts: 17,986
    Did not know that mm, thanks. Makes a little more sense why there are different speaker taps now.
