Turntable preamps...
steveinaz
What are some good turntable preamps that don't require a second on the mortgage?
Post edited by steveinaz on
Cambridge 640P and Jolida JD 9A."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Pro-ject tube box II and Moon LP3.DKG999
Music System: Magnepan 1.6QR, SVS SB12+, ARC pre, Parasound HCA1500 vertically bi-amped, Jolida CDP, Pro-Ject RM5.1SE TT, Pro-Ject TubeBox SE phono pre, SBT, PS Audio DLIII DAC -
Dynavector,P-75,, works well with most cartridges, lo-output mc's,, currently using one in the "enhanced"mode,, should be able to find one used for 325-350--good luck,,let us know what you end up with.JC approves....he told me so. (F-1 nut)
Another vote for the Jolida 9A; very flexible settings & gain; will work with any cartridge._________________________________________________
Anything good about the Bellari Vp129 Tube Phono?Speakers: SDA-1C (most all the goodies)
Nad PP-2"Just because youre offended doesnt mean youre right." - Ricky Gervais
"Consistency requires you to be as ignorant today as you were a year ago." - Bernard Berenson -
Graham Slee
This the best phono stage I've ever heard . . . I will own one as soon as I get tired of my Jolida, which won't be anytime soon:)
This may be the best budget phono stage. Sometimes I wish I had bought it instead of my Jolida.
Phono Preamp Stage: Gram Amp 3 Fanfare
http://www.gspaudio.co.uk/preamps/gram_amp_3_fanfare.htm -
Steve, it really depends what type of phono cartridge you are going to be using. There are plenty of cheap phono preamps that work well with MM type cartridges, but when you move to MC, especially the low output type, then you need to have a more versatile phono preamp.
In the realm of versatile units, I've always been fond of the original Phonomena (by Musical Surroundings). They pop up on Audiogon frequently for around $300. That will work with virtually any phono cartridge out there and sound good doing it.
Also, there was one made by Monolithic that got many favorable reviews and will work with nearly any cartridge as well. It can come with just a wall wart power supply, or a fancy matching box. I think the combo is the PS-1 (phono stage) and HC-1 (power supply) or some variation of that. They also pop up on A-gon and tend to go for the same price range as the Phonomena. I've read the HC-1 is worth the extra money.
Have you picked up a vinyl rig yet, or are you just getting some ideas in place? -
+1 to that. Dusty at CI Audio also had a nice inexpensive VPP-1 Phono Stage, though IIRC it is no longer in production. Hagerman has an inexpensive battery operated phono preamp for MM cartridges. Avaialble as a kit or fully assembled, power supply kit now available. http://www.hagtech.com/bugle.htmlSalk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
I've got one. Pretty solid- I prefer my Audio Research, but it cost 3 times as much. If you've got a MM cart, go with the Bellari.Gallo Ref 3.1 : Bryston 4b SST : Musical fidelity CD Pre : VPI HW-19
Backburner:Krell KAV-300i -
http://www.bottlehead.com/et/adobespc/Seduction/seduction.htm This is the one I use.
www.hagtech.com several models; tube or solid state; excellent -
Thanks fellers for the ideas/input. Right now I'm just fishing for information, and re-educating myself on turntables/cartridges/pre's--it's been awhile.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
I have Cambridge 640P and considered selling it, but after listening to it more and more, I like it better than my Carver C-1 or CT-28v.Panasonic PT-AE4000U projector for movies
Denon AVR-X3600H pre/pro
B&W CDM1-SE fronts
B&W CDM-CNT center
B&W CDM1 rears on MoPADs
DUAL NHT SubTwo subwoofers
Oppo BDP-93 Blu-Ray player
Belkin PF60 Power Center
Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room -
I still prefer the phono section of my last two McIntosh preamps, but for the price, you can't go wrong.I have Cambridge 640P and considered selling it, but after listening to it more and more, I like it better than my Carver C-1 or CT-28v.
In case you haven't seen this yet: http://www.wiredstate.com/forum/viewtopic.php?f=33&t=19390&st=0&sk=t&sd=a&sid=b173c643139e47caa19f474876df57b2
I plan on going the same route with mine."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
I also have the 640P. Can't tell you how good it is yet because I don't have a TT yet but it's very affordable. -
Be careful working with the CA gear. Surprisingly enough, IMHO, even though it sounds and looks fantastic, the build quality is not that good. Keep your soldering iron temperature really low. The build of the actual PCB is poor.Panasonic PT-AE4000U projector for movies
B&W CDM1-SE fronts
B&W CDM-CNT center
Thanks for the heads up. I usually like to live dangerously and keep the Weller pinned.
