Bass reflector
I have a vm 20 and 2 vm 30's. I hear nothing from the bass reflector, should I?
the vm 30 has 4 of them, I should here as the info says deep base. Is ther a test to do to make sure they are working and not defective, they are new but will return if broke.
Post edited by kitkat on
Hello and welcome to the forum. Are you 100% certain that you are playing tracks that have bass? Also, are your speakers wired all in phase correctly?~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~
What are you using to power your speakers?
If you are using a receiver to power them make sure your speaker setting for the fronts is set to LARGE (assuming you have the VM30s for the fronts). When set to small the lower bass frequencies are not sent to the front speakers. You can also check your speaker wire to make sure they are hooked up properly. If you have your speaker wire reversed it will be out of phase resulting in low bass response. -
well , being that they are new, i just posted the pics to the show case, I am running a onkyo 805, brand new monster cable 16G? speaker wire,. the onkyo system does not give you the large/ small config like other receivers, and the + and - are connected properly. But tell me, What should i hear, and feel when i place my hand on the bass reflector(radiator)?Thanks
Set the crossover frequency for "full band". That's the equivalent of setting the speaker to large on the Onk's.The nirvana inducer-
APC H10 Power Conditioner
Parasound Halo P5 preamp
I am interested hearing more about your VM!!! Your setup is awesome!! I am thinking about buying VM or RTI a series.
How do you mount your VM10? Also its finally to see someone actual have VM and post pics!!! Thank you!! Itd be awesome if we could talk on AIM or any messenger, i have tons of questions and i think you can help me out.I am 100% BORN DEAF and No I am not kidding! Why am I here? My wife's hearing!
My Home Theater Rig || Television: 58" Panasonic TH-58PZ800U Viera Plasma || Power Conditioner: Power Monster HTS 3600 MKII || Receiver: Onkyo TX-SR805 || Blu-Ray/Gaming: 60 Gigabytes Playstation 3 || Amplifier: Emotiva XPA-5 || Fronts: Polk Audio RT800i || Center: Polk Audio CS245i || Surrounds: TBA|| Subwoofer: TBA -
you can aol im me at sublimazer
Added, you can also add me...
Lazycus Look forward to speak to youI am 100% BORN DEAF and No I am not kidding! Why am I here? My wife's hearing!
the mount for my v10 rears Are similar to these, they support up to 10 pounds, the speakers are 6 or 8 lb ....http://www.avmountsonline.com/proddetail.php?prod=PPM-501B
i bought mine at best buy when i had my mirage v2 omnisat
