Specs for single sealed box for MM124
MOMOcivic
Please if you have the specs on this i would appreciate it...thank you......its almost all put togather...all i need is a sub box...i'll tell you what...putting a pair of mm6's in a 02' civic's doors was no small feat...i can't wait to hear this system with the subs
1 pair MM124
2 pair MM6 6.5
1 Rockford 700s for the subs
1 Rockford 500x for the seperates
1 Rockford One Farad Cap
Sony Xav-7w head unit
All Monster wire, RCA's, fuse blocks and battery terminals.
2 pair MM6 6.5
Post edited by MOMOcivic on
0.88 cubic feet... anything between 0.8 and 1.0 should be ok... ideally leaning to a hair above 0.88 with a little stuffing like 1/2 lb or less.The Artist formerly known as PoweredByDodge
i meant does anyone hace the specs for the wood for a box to make one .881 pair MM124
2 pair MM6 6.5
All Monster wire, RCA's, fuse blocks and battery terminals. -
well if u want a bare bones square plain jane box....
internal dimensions -->
13 inches across the face...
13 inches tall...
9.25 inches deep.
external dimensions -->
14.5 across
14.5 tall
10.75 deep
determined using 3/4 inch MDF / cabinet grade plywood.
that'd give you like 0.9 cubic feet on the dot.
use like 1/2 lb poly fill and call it a day.The Artist formerly known as PoweredByDodge -
momocivic... do u have any pics or tips on how to get them in the doors? i have a 98 civic and it has been hell trying to get the mm6's to fit.Testing
Testing
Testing -
well.....no pics...all i did was put spacers in and grinf basicaly all the plastic on the door that was in the way....i also has to cut about a 1/4 inch ring to fit em....it was a tight squeeze but they fit in and sound AWESOME1 pair MM124
2 pair MM6 6.5
dodge how did you come up with those dimensions?
i dont think the math works out and i wanna make sure i get it right1 pair MM124
2 pair MM6 6.5
13 inches tall...
9.25 inches deep.
all you do is length times height times width -- for a perfect rectangle/square or whatever... if u do a trapezoid or what ever it'll be difft...
anyway...
(13/12) * (13/12) * (9.25/12)
.......... = 1.083 * 1.083 * 0.770833
.......... = 0.9041018
so there's you're 0.9 which is just a hair above 0.88 which i believe will do the best job sealed for that sub for a "square" box.
dodge you the man....i got my 2 sets of mm6'2 in already and man are those some bass **** seperates....i can't wait to put these subs in1 pair MM124
2 pair MM6 6.5
