What subwoofer?
Dunham_3654
I have the RTi A9s, which sub would you guys think would be better the Pro600 or the DSW3000/ or 4000? All I use the setup for is HT. Input would be great, thanks
Panasonic TH50PZ85U
Omnimount Lowprofile Tilt
Sony Playstation 3
Denon AVR-788
Polk RTi A9s
(FXi A6s and CSI A6 coming soon, trying to figure out the sub)
Sony Playstation 3
Denon AVR-788
Polk RTi A9s
Post edited by Dunham_3654 on
I haven't heard any of them, but i'm inclined to think the 4000 would be the best of the three.
Like metal said, the 4000 would be the best of the 3. Any of them will work well though. If budget allows, I say go for the 4000.The nirvana inducer-
APC H10 Power Conditioner
Parasound Halo P5 preamp
What is your room cubic feet including any large openings to other rooms and their Cubic feet.
cf = HxWxL
This will help determine a best recommendation. Polk might work for you but make sure you get the right one or you will be chasing LFE goodness and can't quite catch it.Speakers: SDA-1C (most all the goodies)
If you are buying one subwoofer go for the largest, and most powerful model in the Polk line. You have the option of turning the volume down on the subwoofer, which will make it run with less distortion with all that extra headroom. Cross the subwoofer over low, where it belongs, and the thing will disappear into a thing of beauty.:D
i am a big fan of martin logan subs
Polk 4000 is a fine sub. But if you want to save some bucks spend that amount of money on a sub by Velodyne, SVS, HSU, etc. Companies that mostly 'do' subs, unless you're committed to Polk. In which case the 4000--if you can afford it!
Outlaw Audio makes some nice and reasonable subs also!
