Spade Plugs?
polkyphil38
polkyphil38 Posts: 447
edited June 2013 in Speakers
Folks, I have decided to order a set of the Monitor 50's, the matching CS10, and Monitor 30's for rears. Thus, I do not have the room for a 7.1 set-up. I want to use spage plugs on my speakers. As such, will these work?
http://www.speakerrepair.com/Merchant2/merchant.mvc?Screen=PROD&Product_Code=SR10&Category_Code=spade
Be sure to scroll down the page for more detailed info. I want to order 10 of them for my speakers. Not really sure if these will actually fit or not. If not, what do you use then? I know I can just connect the wire directly, but it always seems to come lose. :o:o I prefer to have a good solid and tight contact. I really like using the safe connect banana plugs on my Yammie 663. As always, any and all feedback will be most appreciated. Have a great afternoon people.
Cheers,
Phil
The way one uses a product is a much more SIGNIFICANT factor than which product(s) he uses.
  • Conradicles
    Conradicles Posts: 6,434
    edited March 2009
    They will work. I have bought some of those exact ones from that same vendor in the past and I really liked them. I would not use them on the amp end, as I feel bananas work better, but they work on all speakers I owned. Good quality IMHO.
  • polkyphil38
    edited March 2009
    Hi, and thanks for posting. I use the Safe Connect type banana plugs on my receiver. I just want to use the spades on my Polk Monitor Series speakers. My center is the TSI CS10 so not sure if that makes any difference or not. Just to make sure, you have used these same exact spades on your Monitor Series speakers AND they worked just fine. Am, I correct here? Appreciate the info.
    Cheers,
    Phil
  • Conradicles
    edited March 2009
    Not on the Monitor series you own, but on other Polk/Infinity/Cerwin Vega/the list goes on and on type speakers.
    I see no reason why they will not work. They are just standard spades. Enjoy.
  • polkyphil38
    edited March 2009
    Okay, I just ordered 10 of them. I also needed a few banana plugs. Thanks for your help.
    Cheers,
    Phil
  • skrol
    skrol Posts: 3,497
    edited March 2009
    They look very much like the Monsters that BB has on clearance (4 for $16.99).
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • ben62670
    ben62670 Posts: 15,969
    edited March 2009
    GLS uses the same connectors as ~M~ in a lot of their stuff. Don't sue me!
    Ben
  • polkyphil38
    edited March 2009
    skrol wrote: »
    Yeah, I have to agree here. I have ordered from them before albeit banana plugs, but have never used the spades. Oh well, I will know soon enough as they are on their way. ;);)
    Cheers,
    Phil
  • polkyphil38
    edited March 2009
    ben62670 wrote: »
    LOL.........too funny. It is true, though, that Monster likes to file law suites. As such, I can certainly understand your concern..........LOL!!!! :p:p
    Cheers,
    Phil
  • skrol
    skrol Posts: 3,497
    edited March 2009
    You didn't just actually use the "M" word did you?:eek:
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • polkyphil38
    edited March 2009
    skrol wrote: »
    Oops my bad! :eek::eek:
    Cheers,
    Phil
  • polkyphil38
    edited March 2009
    Folks, got the spades in from speakerrepair.com and they fit perfectly. Thanks to all of you that helped. BTW, speakerrepair is a great company to deal with. Great prices and fast shipping. Kudos to them.
    Cheers,
    Phil
  • decal
    decal Posts: 3,205
    edited June 2013
    esteamshower spammer reported
