how important is "timbre" match with speakers?
poloman1211
There is alot of talk of getting speakers that timbre match but if a recevier can calibre the speakers, so cant you get all the speakers to "timbre match" ? or am i completely off?
thanks
thanks
Post edited by poloman1211 on
Timbre matching refers to the actual sound of the speakers. Different speakers have different sounds. The tweeters/mids/woofers in the RTi series are going to sound much different than the tweeters/mids/woofers in the LSi series.
Timbre matching isn't something that can be corrected through calibration in an AVR. You are much better off with a timbre matched setup though. Affects that go from front to back, or across your front soundstage sound much better with a timber matched setup.The nirvana inducer-
APC H10 Power Conditioner
Parasound Halo P5 preamp
Yep, Curt is right on the money with this. However, occasionally you can get lucky like me, it seems my CerwinVega center matches up nicely with my R50's up front. (I do wonder what it would sound like with a CS10 though).;)Polk Audio Surround Bar 360
Mirage PS-12
LG BDP-550
Motorola HD FIOS DVR
Panasonic 42" Plasma
XBOX 360[/SIZE]
Office stuff
Allied 395 receiver
Pioneer CDP PD-M430
RT8t's & Wharfedale Diamond II's[/SIZE]
Life is one grand, sweet song, so start the music. ~Ronald Reagan -
There is at least one of our Polk Gurus who's said timbre matching doesn't matter as long as it sounds good to 'you'. Can't remember who that was. But maybe he'll show up in this post.
As for me...I'd go with Curt, et.al, above.
On the reincarnation scale I'd say I'm an 'insect' and will never make it to Guru. Too much BAD karma and sins galore?
I've mixed and matched a few centers and mains and having a timbre matched front stage will always sound more convincing. IMO, it's not as important with rears, but I would still recommend it."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
That would be me. Timbre matching is for wussies.:eek:HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes."
