Can any pre-amp be mod for HT bypass?
disneyjoe7
The title pretty much sums it up.
Electrically how are these pre doing it?
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR
Post edited by disneyjoe7 on
Yes. You put a switch on it just before the pre-out RCA's. In one position it takes the output from the pre; in the other position it take the output directly from the HT-bypass input.
Modding an integrated is a little more involved.Gallo Ref 3.1 : Bryston 4b SST : Musical fidelity CD Pre : VPI HW-19
Backburner:Krell KAV-300i -
Could a relay be used also, I figured a 4PDT may do the tick. This way it's auto bypassed if off, for HT mode. Cool or NO NO?
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
WMC Win7 32bit HD DVR -
I'd prefer a switch, but there's no reason a relay wouldn't work. Also, all the grounds are usually tied, so a DPDT will work. I've traced some bad channel seperation back to the grounds being tied, but it's a lot of work to swap out all the switches to have twice as many poles to do the ground switching, too.Gallo Ref 3.1 : Bryston 4b SST : Musical fidelity CD Pre : VPI HW-19
With a DPDT switch or relay, are you splitting both out and input to them self vs. to original circuit?
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
OK, with a DPDT, I was assuming that you'd have a dedicated HT bypass input that could not be run through the pre.
With 4PDT, you could disconnect one of the inputs from the pre and route it straight to the output.Gallo Ref 3.1 : Bryston 4b SST : Musical fidelity CD Pre : VPI HW-19
Ok I see your point, but I considered doing this to a pre which doesn't have a HT input using an existing input for such propose.
But I don't think that is an issue also, as I found my AVR will not give me a fixed level output from the tape outputs. I was trying to use the AVR for the dac as two sources are digital inputs. As this didn't work out, your idea with the DPDT would work also. I thought most pre had a HT bypass as it seems very popular, but I don't see a lot listed as such used that is. I could see playing with a "Cheap" pre but would have an issue modding a Nice pre. I'm just playing with the pre idea, with my HT / 2 channel setup.
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
