What kind of amp should I buy
Systems
Systems Posts: 14,873
edited March 2003 in Car Audio & Electronics
I just bought 2 Polk GNX 12" subs and I don't know what kind of amp i should get. Anyone got any suggestioins?
Testing
Testing
Testing
  • PoweredByDodge
    PoweredByDodge Posts: 4,185
    edited February 2003
    hey dude...
    well it depends on the impedance of your woofers... singel 4 ohm coil? dual 4 ohm coil? single 8 ohm coil?
    my suggestions -->
    if single 4 ohm coil...
    - wire in parallel
    - amp: mtx 4250D, JBL BP 300.1, RFPunch 301M, RFPower 351M, Alpine MRD-M300
    all will give you between 300 and 350 x 1 at 2 ohms so 150 - 175 per sub.
    if dual 4 ohm coil or single 8 ohm coil...
    -parallel down to 4 ohms (single 8) // series then parallel down to 8 (dual 4)
    -amp:
    [300 - 350 x 1 bridged - so 150 - 175 or so per sub]
    RF Punch 301S, Pioneer GMX-972, Alpine MRV-T420, Kicker KX300.2
    [400+ x 1 bridged - so 200+ per sub]
    Kicker KX400.2, RF Punch 401S, RF Power 351S, mtx 302/8302
    The power 351S and the mtx 302 are probably overkill, thats a personaly preference... I'd lean toward the Kicker 400.2 if i was being "normal" about it.
    The Artist formerly known as PoweredByDodge
  • technobass
    technobass Posts: 25
    did you give those ratings in max power or rms???
    Steevo a.k.a. DJ Nostalgia
  • PoweredByDodge
    RMS .. max power is for pussies... lolol
  • sntnsupermen131
    sntnsupermen131 Posts: 1,831
    edited March 2003
    only companies like sony and jensen use "peak power" to sell their products b/c it is literally useless
    rms power is the only thing you ever need to know
    -Cody
  • PoweredByDodge
    edited March 2003
    gotta love the sony amps that are plastered w/ a big "800 w" sticker -- then u realize they're like 350 rms... and then u even further realize that at their true rated 350 they in fact start to overheat and go into protect like its no body's business.
