resistance on speakers
edited March 2009 in Speakers
Ok I have a dumb question, I just bought some used Lsi 9's and a friend of mine that does some messing around and repairs on stereo equipment wanted to check them out he has never seen a pair. I took them over to him today and he thinks that there might be something wrong with the top driver on both speakers, maybe overdriven but I don't think so. When you check the resistance on the top driver its 2.4 on both speakers then when you check the bottom driver its 3.9 thats where he thinks it should be. I really don't know maybe someone here can shed some light on the subject. Oh and by the way the tweeter checks out at 3.2 on both speakers. Just wondering if this is the way they all are or if the previous owner just played them way too hard, they do look like they have had a really hard life for just being bookshelfs.
Sig to be updated after dealing with the insurance company:(:(:(
Post edited by raidersrule76 on
    edited March 2009
    I am not an engineer or savvy with scientific terms, But can you check the Resistance at the Speaker Connector terminals (Binding Posts) if still doubtfull call up Polk Customer Service they will be able to help you out. And by the way the Lsi s are rated at 4ohms.:)
    edited March 2009
    The 3.9 and 3.3 may be acceptable, but the 2.4 definitely isn't right.
Welcome!
Welcome!
