TT Periphery Ring Clamps
jm1
jm1 Posts: 618
edited March 2009 in 2 Channel Audio
Since I have been labeled as a depleted genes Club Polk member, I though I would rebel once again and post a link to an external thread discussing a Periphery Ring Clamp which can be used with most TTs.
Audiogon Periphery Record Rings thread
Might be interesting following this thread if you have ever though of using one. Having a VPI TT, I am using the VPI Periphery Ring Clamp. I wouldn't play a record without using this.
All truth passes through three stages. First, it is ridiculed, second it is violently opposed and third, it is accepted as self evident.
Arthur Schopenhauer
Post edited by jm1 on
  • schwarcw
    schwarcw Posts: 7,341
    edited March 2009
    I understand your bliss. I've used Joe's "The Clamp" and I was amazed at the difference that made on my vintage turntable setup. I also heard the clamp in action on Analog97's VPI. We were both amazed at the impact the clamp has on the sound.
    Carl
  • bikerboy
    bikerboy Posts: 1,211
    edited March 2009
    I use Joe's The Clamp and it is amazing. It makes sense to couple the 180 gr lp to the 11 kg platter. We do so much to make the TT solid but just let the lp float on the platter.
    Main system: Lyngdorf TDAI 2170 w/ Pioneer 42" plazma-> Polk LSiM 703 w/Tivo, Marantz tuner, BRPTT: Nothingham Spacedeck-> Pioneer PL L1000 linear arm-> Soundsmith DL 103R-> SUT->Bottlehead ErosDigital: I3 PC w/ Jriver playing flac -> Sonore Ultrarendu -> Twisted Pair Audio ESS 9028 w/ Mercury IVY Vinyl rips: ESI Juli@24/192-> i3 PC server
    treitz3 Posts: 19,273
    edited March 2009
    I'd like to get one but at the cost of what they go for, I might as well have one manufactured for me to my specifications. I also use Joe's "The Clamp" and it does wonders for vinyl listening. There will never be a reason to upgrade that area of my rig as Joe IMO has built the perfect clamp.
    I'm either looking into a vacuum system to keep the LP down or looking into getting a ring made for the outer edge.
  • Systems
    Systems Posts: 14,873
    edited March 2009
    Hello
    Where do you purchase Joes "The Clamp" at? I did a search on google but nothing came up about it...
    Testing
    Testing
    Testing
  • shack
    shack Posts: 11,154
    edited March 2009
    Lorthos wrote: »
    Hello
    That would be our own hearingimpared.
    http://www.polkaudio.com/forums/showthread.php?t=47286
    If you don't have one...you maybe SOL...in order to get one someone will have to sell you theirs beccause I don't think Joe has any more. I know I'm not selling mine. I still think Joe needs to figure out how to make and sell them again now that vinyl is in a nice resurgence.
  • Systems
    edited March 2009
    shack wrote: »
    Okay, thanks! Looked at the thread, does look pretty slick alright. I take it he make them on his own lathe or he had an access to a machine shop...
    Testing
    Testing
    Testing
  • hearingimpared
    hearingimpared Posts: 21,136
    edited March 2009
    I have one left. Lorthos PM on its way.
  • Systems
    edited March 2009
    Okay, thanks, will look for it......
    Testing
    Testing
    Testing
  • hearingimpared
    edited March 2009
    John thanks for posting this thread as I am getting lot's of requests for my last clamp.
    edited March 2009
    .....as I am getting lot's of requests for my last clamp.
    Hint, hint Joe. Hint hint..........;)
  • hearingimpared
    edited March 2009
    Lorthos . . . PM headed your way.
  • fbm211
    fbm211 Posts: 1,488
    edited March 2009
    How much to get one made joe????Or do you know of a nice alternative?
    SDA-2BTL with custom IC
    Harman Kardon T-55c TT
    DH LABS REVELATIONS ICs-amps
    Revelation Audio Labs Paradise cryo-silver ICs-Source to pre
  • hearingimpared
    edited March 2009
    fbm211 wrote: »
    The cost of having just one make is astronomical and would break your bank. An alternative that would get you particially there would be this one.
    http://store.acousticsounds.com/browse_detail.cfm?Title_ID=36249
  • fbm211
    fbm211 Posts: 1,488
    edited March 2009
    Thanks for the link. Ill be getting one in a few days..Do you know of any place that can buff a dust cover to make it almost like new??
  • hearingimpared
    edited March 2009
    fbm211 wrote: »
    If I did mine wouldn't be so scratched up!:eek::o
  • Polkersince85
    Polkersince85 Posts: 2,883
    edited March 2009
    fbm211 wrote: »
    Try Meguiar's PLASTX from the auto parts store. Designed for auto headlight lens.
  • gdb
    gdb Posts: 6,012
    edited March 2009
    fbm211 wrote: »
    Auto restoration supply outfits sell a string buffing wheel (for low rpm buffers) and a special compound, (rouge) for resurfacing plastic lenses and trim parts. Wear a mask !!!:eek:
    http://www.caswellplating.com/buffs/stringbuffs.html
  • fbm211
    fbm211 Posts: 1,488
    edited March 2009
    I knew I had read somewhere that it was possible to buff out scratched dustcovers.Maybe not like new but anything would be better than my vintage 25year old scratched HK dustcover.
  • thsmith
    thsmith Posts: 6,082
    edited March 2009
    Joe recommended this clamp to me and it works great. Took it over to friends house and we A/B tested it on both his TT, he is a believer and will order one this week.
    THANK AGAIN JOE !
