Polk Direct Warranty Change
metal83
metal83 Posts: 1,219
edited March 2009 in Speakers
Polk has changed the warranty on refurbs from 5yrs to 2yrs for their speakers. Not sure when this happened, as i just bought my A7's from them in January and was told they have a 5yr warranty.
http://www.polkaudio.com/support/warranty-returns.php#q9
Post edited by metal83 on
    treitz3 Posts: 20,001
    edited March 2009
    Nothing is valid unless it's in writing.
    That said, the economy may be putting a pinch on Polk [I don't know.....just saying.....] and they may be acting accordingly. At least you know up front what you are dealing with.
    As far as your situation is concerned.......contact Polk CS. Hear it from the horses mouth.
  • metal83
    edited March 2009
    treitz3 wrote: »
    As far as your issue, contact Polk CS.
    When i bought these i was told directly by Polk CS (the horses mouth) that i have a 5 year warranty. I guess i should of requested this in writing though.
    I don't have an issue.
    But i will call them again to make sure that i still have the 5yr warranty.
    edited March 2009
    I wouldn't sweat it. Polk has the best reputation that I know of when it comes to CS. I was just thinking off the top of my head when I wrote that response. The economy has hit all factors of business that I have been in contact with. Sign o' the times I guess?
    Or maybe just an executive decision.
  • metal83
    edited March 2009
    I mean it does suck that they dropped 3yrs from the warranty.
    But at the same time it won't prevent me from buying from Polk Direct.
  • metal83
    edited March 2009
    Now if Polk Direct would get some black A9's anytime soon, my speaker upgrade itch would be done for quite some time, and i'd be one hell of a happy camper!!!!!:D
    Toolfan66 Posts: 18,067
    edited March 2009
    I am not to worried about it, i have had the RT55i's for almost ten years, naver had a problem with them once, they still sound just as good as the day i got them + IMO if there is going to be a major problem i think it would happen in the first year. also with that said im sure they would hook you up with what ever you needed to fix the problem with little cost if any at all.
  • metal83
    edited March 2009
    Yeah i'm not really worried at all to be honest. Just the fact that i was told i have a 5yr warranty, and now it's changed, is of course going to make me want to call and make sure my 5yr is still intact.
    I'll still be buying from Polk Direct, no question about that. :)
  • comfortablycurt
    comfortablycurt Posts: 6,745
    edited March 2009
    I'd have to guess that only applies to new purchases. If you bought something from Polk Direct before the change, you probably still have the 5 year warranty. The 2 year warranty is probably only applied to products purchased after the change.
    I may be wrong on that, but just my 2 cents.
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
  • metal83
    edited March 2009
    Well yeah that would make the most sense of course, i agree.
    But like i said, i'll still call to find out, that will have to wait until Monday though.
    I have to call them anyways to inquire about some A9's, might as well kill two birds with one stone. ;)
  • Spike111
    Spike111 Posts: 15
    edited March 2009
    Thanks for pointing out the change metal. I will have to call on Monday to find out. I just purchased my LSi 9's and 7's on 2/7 and the eBay listing said 5 years but the LSiC I ordered yesterday only said 2 years.
    AVR: Marantz 7008
    AMP: Emotiva XPA-5
    Mains: LSi 15
    Center: LSiC
    Side Surronds: LSi 9
    Rear Surronds: LSi 7
    Sub: eD A2-300
    Bluray: PS3
    Turntable: Rega P2
  • tcrossma
    tcrossma Posts: 1,301
    edited March 2009
    I didn't read all this *too* closely, but I think this might actually be a clarification and extension of the Ebay warranty policy instead of a reduction:
    http://www.polkaudio.com/forums/showthread.php?t=66196&highlight=warranty
    I believe their terms used to indicate a 180 day warranty for Ebay refurbs, which now appear to be 2 years. It was *not* 5 years before, even though their documentation seemed to indicate it was.
    Speakers: Polk LSi15
    Amp: Pass Labs X-150
    CD/DVD Player: Classe CDP-10
    TT:Micro Seiki DD-35
    Cartridge:Denon DL-160
    Phono Pre:PS Audio GCPH
  • kneedragger37
    kneedragger37 Posts: 108
    edited March 2009
    The following was copied from an old ebay auction page from Polk direct. Anyone care to speculate on the difference between "remanufactured" and "refurbished?"
    You are bidding on a Factory Refurbished product, direct from Polk Audio. It comes direct from Polk Audio and has the original factory warranty. To learn more about what Factory Refurbished means, click here.
    Remanufactured for home speakers and electronics
    Limited Five Year Warranty
    Polk Audio, Inc., warrants to the original retail purchaser only. This warranty will terminate automatically prior to its stated expiration if the original retail purchaser sells or transfers the product to any other party.
    Polk Audio, Inc., warrants, to the original retail purchaser only, that the LOUDSPEAKER(S), PASSIVE CROSSOVER COMPONENT(S) and ENCLOSURE on this Polk Audio Loudspeaker Product will be free from defects in material and workmanship for a period of five (5) years from the date of original retail purchase from Polk Audio.
    Furthermore, Polk Audio, Inc., warrants, to the original retail purchaser only, that any AMPLIFIER OR OTHER ELECTRONIC COMPONENT that may be included in this Polk Audio Loudspeaker Product will be free from defects in material and workmanship for a period of three (3) years from the date of original retail purchase from Polk Audio.
    Refurbished for home speakers and electronics
    Limited One-Hundred and Eighty Day Warranty
    Polk Audio, Inc., warrants, to the original retail purchaser only, that the LOUDSPEAKER(S), and PASSIVE CROSSOVER COMPONENT(S) on this Polk Audio Loudspeaker Product will be free from defects in material and workmanship for a period of one-hundred and eighty (180) days from the date of original retail purchase from Polk Audio.
    Furthermore, Polk Audio, Inc., warrants, to the original retail purchaser only, that any AMPLIFIER OR OTHER ELECTRONIC COMPONENT that may be included in this Polk Audio Loudspeaker Product will be free from defects in material and workmanship for a period of one-hundred and eighty (180) days from the date of original retail purchase from Polk Audio.
    Furthermore, Polk Audio, Inc., does not warrant any COSMETIC APPEARANCE, IMPERFECTIONS OR BLEMISHES on this Polk Audio Loudspeaker Product.
  • jacob.simpson
    jacob.simpson Posts: 481
    edited March 2009
    If i get it right what i read in the eBay terms for Polk refurbs its 2 years on speakers, for all the new ones its still 5 years
  • DollarDave
    DollarDave Posts: 2,575
    edited March 2009
    Sort of on subject, but did anyone notice that Polk Direct has over 180 listings on e-bay right now? About a year ago, e-bay had about 300 - 350 total listings. Now, over 700 listings.
    Sign of the times, I guess. Polk is selling more direct product (they can't have 180 defective/returned products at any given time) and others must be selling their surplus. Just guessing on these observations.
  • mmadden28
    mmadden28 Posts: 4,283
    edited March 2009
    tcrossma wrote: »
    Eric at Polk CS clarified this (on this board) not too long ago. The warranty wording on the eBay site was unclear. He verified that in fact the refurb speakers had the full 5 year warranty, but that the other electronics (iSonic, etc) had 180 days. I recall the site was updated with direct clarification of the terms showing 5 years for refurb speakers. I'll see if I can find that thread.
    However it is clear from the warranty statment now that it has been reduced to 2 years, but before that change it would be 5 years not 180 days (although I'm still not sure why my Lsi9's had that 180 day sticker on it. :()
    ____________________
    Pool: Atrium 60's/45's
  • mmadden28
    edited March 2009
    Here it is:
    Eric Wong wrote: »
    You're right the wording is confusing. We will change the lingo.
    Here is the bottom line on refurbished Polk goods:
    Electronics (e.g. I-Sonic, subwoofer amplifiers, miDock, tuners, etc.) have a 180 day warranty.
    Home speakers have a 5 year warranty (original warranty).
    Keep in mind this thread was from Dec and would no longer be relevant for any new purchases from Polk Direct since they meade the change.
  • cfrizz
    cfrizz Posts: 13,415
    edited March 2009
    While it might be nice to have a warrenty, I wouldn't worry too much. My speakers are 19years old & still going strong.
    Polk builds them to last.
  • comfortablycurt
    edited March 2009
    Refurbished speakers are speakers that were returned, and have been certified to be in good working order as is, and may contain some minor cosmetic imperfections.
    Re-manufactured speakers, are speakers that have had drivers, or crossover parts replaced to bring them back to new condition. They may also contain minor cosmetic blemishes though.
    edited March 2009
    Is it possible that such a change in policy is just an addendum to the fact that Polk is now providing a link to the Polk Direct ebay site above?
    And that it doesn't make a lot of business sense to offer the same warranty as they do on store bought/i-net NEW products as on Direct purchases!
    Just a thought?
    cnh
  • mdaudioguy
    mdaudioguy Posts: 5,165
    edited March 2009
    FWIW, I received a letter in the mail this past week from Kenneth Swauger of Polk. The purpose was to reassure me that my pair of RTi10 speakers purchased almost a year ago from Tweeter would still be covered under Polk's full warranty, even though Tweeter has since closed its doors. Honestly, I wasn't concerned much about it, as I figured that if a dealer went away, the manufacturer would still be there. I guess enough people were worried about this that Polk thought it would be good to offer this reassurance. In any case, the letter was unexpected, but nice to receive. Good CS.:)
  • mmadden28
    edited March 2009
    cnh wrote: »
    Just a thought?
    cnh
    I assume when you say "Direct" you are referring to Polkdirect on eBay and not internet direct sales in general, right?
    Your right, it does not make a lot of business sense to sell what amounts to refurb products at the same time as their NIB product and still offer the same warranty, esp when the refurb product (esp the speakers) are essentially NIB as it is.
    I think a 2 year warranty on what is sold as 'Refurb' is still reasonable enough for me. After all, warranties cover manufacturer defects, 2 years on a speaker should be long enough to uncover most of those defects, no?
  • metal83
    edited March 2009
    mdaudioguy wrote: »
    I got the same letter in regards to the RTi10's i bought last May.
    Of course i don't have them anymore, but still...;)
    edited March 2009
    mmadden28 wrote: »
    You're right, I should have said Polk's Direct Ebay site.
    cnh
  • Eric W
    Eric W Posts: 556
    edited March 2009
    mmadden28 wrote: »
    You're correct- the warranty for refurbished products (purchased from our eBay direct store or directly from us) has changed to 2 years for in-home speakers. Refurb electronics was always 6 months (180 days).
    We are going to make a sticky about the warranty questions.
    -Eric
    -Polk Audio
  • CaligulaPolk
    CaligulaPolk Posts: 1,650
    edited March 2009
    Eric Wong wrote: »
    what was the reason for the change?
    I am 100% BORN DEAF and No I am not kidding! :D Why am I here? My wife's hearing! :p
    My Home Theater Rig || Television: 58" Panasonic TH-58PZ800U Viera Plasma || Power Conditioner: Power Monster HTS 3600 MKII || Receiver: Onkyo TX-SR805 || Blu-Ray/Gaming: 60 Gigabytes Playstation 3 || Amplifier: Emotiva XPA-5 || Fronts: Polk Audio RT800i || Center: Polk Audio CS245i || Surrounds: TBA|| Subwoofer: TBA
  • shack
    shack Posts: 11,154
    edited March 2009
    Good grief...A 5 year warranty on a refurb item goes way beyond what is normal for the industry. 2 years is an excellent warranty under theses circumstances. While offering the full 5 years on a refurb item sounds nice...it is not necessarily a good business practice if Polk is to be around for the long term.
  • metal83
    edited March 2009
    Two years is most certainly still great, especially considering the prices in which the refurbs sell for, no complaints here! I look forward to purchasing more items from Polk Direct.
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited March 2009
    I heard if a senior Polk Employee rubs their dingus on the speaker the warranty is extended,..........get it,---dingus----extended............
    RT1
    edited March 2009
    Like i have said i have no concern. My A9's are refurbs if there was something wrong with them it was fixed right? to me i feel i will never have a problem with them, And if i do i will just fix them with polks help if need be.
    I also look at it this way, i am the one that hooked them up, and i am also the one that controls the volume. so some of the responsibility on how long they last is on me.
  • mmadden28
    edited March 2009
    ... to me i feel i will never have a problem with them....
    :eek: Hurry go knock on that wood veneer--Hurry or your gonna be sorry you said that. :eek: ;)
