Which front speakers to use?
pinoygwaping
pinoygwaping Posts: 20
edited March 2009 in Speakers
I have a pair of R50 as my front speakers and R300 as my sorround sound. Now I just bought a pair of Monitor 50, Which front speaker I have to use the R50 or Monitor 50? I did tried them both and can't decide which one is better. I know that the R50 is taller than the Monitor 50. Now I'm staring on both model and I don't know which one use. I'm using a CS2 (Center Channel) and 2 PSW10 as sub. Please let me know. Thanks in advance.
Post edited by pinoygwaping on
    nooshinjohn Posts: 25,901
    edited March 2009
    monitor 50's... I ran them for two years before I got my SDA's.
  • Braddles
    Braddles Posts: 228
    edited March 2009
    If you can't tell the difference when you listen to both then it doesnt matter does it?
    Trust your ears. They dont lie.
    That said i would guess the Monitor 50's would blend better with your center.
    Amp - Jas Audio Bravo 3.2 set
    Power Cord - Tunami GPX
    CDP - Marantz cd6002 - Audio gd Ref 5 Dac
    Speakers - Tekton Lore,Polk Audio RTA11tl completely refreshed.
    edited March 2009
    The CS2 and the M50s have the same tweeter which is superior to the R series version. You should listen more closely to your highs for that. M-50s, IMHO, also image better?
    cnh
  • Mike21
    Mike21 Posts: 252
    edited March 2009
    Hi pinoy.
    Upon the advice of a Polk corporate marketing dude (the infamous Marko Polko), I bought a CS2 to match my M50s. Perfect match.
    ____________________________________________
    Home Theater 32"LG LCD; Comcast; 7.1 Onkyo 805; Fronts: Polk M50s; Center: Polk CS2; Sides: Polk M40s; Rear: B&W LM1s; Subs: (2) Sony 12" x 100w; Samsung 1500BDP; Toshiba A-2 HD-DVDP.
    PC stereo: Viper custom PC: Windows XP; ASIO4ALL; JRiver Jukebox> Pop Pulse USB to S/PDIF conv> Monarchy DIP > Musiland MD10 DAC > Parasound 2100 pre> Aragon 4004 MKII amp> Dali Ikon6 towers; Sunfire True Sub; PSA Duet, Ultimate outlet and Noise Harvestors.
