wiring from AVR to Sub and Main L/R
bearro
Can the Sub and Main front L/R be bi wired from the AVR's front L/R speaker terminals without running the wires to the main speakers thru the Sub. I am pushing 100 watts per channel with a Sony 5.1 AVR.
"If it ain't broke,keep fix'n it till it is."
Post edited by bearro on
Or should I use the LFE to drive the sub. The manual says they will sound better if wired thru the speaker terminals.
I would use the LFE, that's what I used on my setup and it sounds good to me. There is another thread on this, and there are a few different opinions on it. Here is a link....
http://www.polkaudio.com/forums/showthread.php?t=79563HT Rig
Receiver- Onkyo TX-SR806
Mains- Polk Audio Monitor 70
Center- Polk Audio CS2
Sub- Polk Audio PSW125
Blu-Ray- 80 GB PS3
2 CH rig (in progress)
It's not that I'm insensitive, I just don't care.. -
Hi bearro
What make is your sub? I know there is at least 1 make (can't recall which) that designs its subs to be speaker wired rather than the usual LFE RCA connection.____________________________________________
Home Theater 32"LG LCD; Comcast; 7.1 Onkyo 805; Fronts: Polk M50s; Center: Polk CS2; Sides: Polk M40s; Rear: B&W LM1s; Subs: (2) Sony 12" x 100w; Samsung 1500BDP; Toshiba A-2 HD-DVDP.
PC stereo: Viper custom PC: Windows XP; ASIO4ALL; JRiver Jukebox> Pop Pulse USB to S/PDIF conv> Monarchy DIP > Musiland MD10 DAC > Parasound 2100 pre> Aragon 4004 MKII amp> Dali Ikon6 towers; Sunfire True Sub; PSA Duet, Ultimate outlet and Noise Harvestors. -
I tried both and prefer the LFE RCA mono jack. After all that is what that LFE output is for on your AVR. However like on my Polk Audio PSW111 there are a number of options on the back of the sub to connect. I practice the KISS method and use the LFE
My sub is a Polk RM6000
Def LFE on any Polk sub.____________________________________________
