Dynaco recapping?
How do I know if my Dynaco A-25 speakers need recapping or crossover work? They seem to sound fine, but I'm sure they would sound better if they need to be worked on.
Post edited by raymeedc on
Maybe the first thing to think about is the quality and age of existing caps.
Being that the A-25 is from the late 60s or early 70s, the caps will most likely be dried out. But more than that, crossover component technology has come a long way since then and new components sound so much better than the old ones. With a classic design like the A-25 with Seas drivers, I'd replace the components.
Agreed. You could go at it two ways:
1. Replace inductors, caps, resistors with same board.
2. Get a whole new crossover.Living Room:....................[HTML] [/HTML] Zone 2 (Workout Room):
AVR - Yamaha RX-V757......JBL 4312 Pro Monitors
Pre - Nak CA-5
AMP - Adcom 555 (Main)
Main - Polk RTI8**/RTiA5
AMP - Adcom 545II (Center)
Center - Polk CSiA4**
Sub - Snell Basis 300:p......Zone 3 (Outside)
CD - Yamaha CDC-555.......Def Tech AW5500
TV - Pani TH-42PZ80U
BR - LG BD390
Monster HTS1600 Power Center
Dedicated Circuit - (2) 20amp, (1) 15amp
Ben's IC, Canare 4S11
**Dayton and Sonicap Caps with Mills Resistors** -
K.I.S.S
Just replace the old caps with new ones of the same value. Don't worry about voltages though, higher is ok."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
