Passive rattle w/ stripped screws
dagame27
dagame27 Posts: 576
edited March 2009 in Vintage Speakers
I have recently heard an intermediate rattle in my SRS 2's. Upon examination, it's coming from the left passive radiator. I also noticed that two screws aren't grabbing. Using search, I found that Noel (ND13) had the same issue, (these are his old speakers), which ended up being a loose crossover. I am going to mess with that this weekend, but was wondering if there is anything I can do about fixing the screws. I am not very skilled when it comes to this kind of stuff, so hopefully it is not too difficult.
ChrisPreamp: Anthem Pre 2L (Jan-Phillips Green) Processor: Marantz SR7012 Amp: B&K 200.5Streaming: Bluesound Node 2IDAC: Eastern Electric Minimax Plus4K Bluray: Panasonic UB820Mains: Von Schweikert VR2Center: Von Schweikert LCR15 Subs: 2 SVS Sb13 Ultra (HT Only) Analysis Plus Cables
Post edited by dagame27 on
    nooshinjohn Posts: 25,461
    edited March 2009
    I would fill the holes with wood putty, packing them as tightly as possible, and then redrill some new pilot holes and reinstall the screws
    treitz3 Posts: 19,211
    edited March 2009
    Or you could stick a toothpick [part of] in the hole and screw it back in for a temporary fix.
    SCompRacer Posts: 8,513
    edited March 2009
    Hardwood dowels is another solid repair. Drill a hole and glue them in, then drill the screw hole. Either buy a dowel rod and cut to length, or purchase a bag of splined dowel rods in various diameters at the hardware store.
  • zarrdoss
    zarrdoss Posts: 2,562
    edited March 2009
    set the speaker on its back and put some tape over the hole on back to prevent glue from running out then squirt some elmers glue in the hole and let it dry. re-drill pilot holes and then put the screw back in but hand tighten the screws be careful not to overtighten. it worked fine for me.
    F1nut Posts: 50,746
    edited March 2009
    SCompRacer wrote: »
    That is the ONLY proper way to repair the damage. Nothing else is worth the bother.
  • Face
    Face Posts: 14,340
    edited March 2009
  • Systems
    Systems Posts: 14,873
    edited March 2009
    Edit:see above.,Mike beat me to it.
    Testing
    Testing
    Testing
  • BAD ASP
    BAD ASP Posts: 361
    edited March 2009
    Two things I would recommend:
    Remove the passive
    1.Carpenters glue (kinda yellow) and a few toothpicks, fill the hole tightly with the toothpicks dipped first in the glue. Wait for the glue to dry and cut off the exposed ends with an endcutter. Sand or file the surface smooth.
    2.Match up a drill bit to the screw you are using. Do this by holding the screw over the bit and make sure that at least the screw threads are wider than the drill bit. You want to make sure that the screw shank is slightly larger that the diameter of the drill bit.
    or
    Abandon the exising mounting holes.
    Rotate the passive radiator about an inch and mark all of the holes and redrill. Remount the passive. The speakers gasket will bridge the old holes. Don't overtighten, just snug them you don't need to crank down, you don't want to compress / flatten the gasket hard to the speaker mount.
    MY2c FWIW
    Amp: sunfire cinema grand signature 5ch 425 wpc
    Side surround amp: Sunfire 2 X 300
    Processor: sunfire theater grand V
    Fronts:: polk sda-srs 1.2
    Rears: Polk LSiFX
    Side surrounds: Fxi5
    Center: (2)polk LSiC's
    Sub: svs pb-13 rosenut
    Hd-Dvd: toshiba xa-2
    Blue Ray: oppo bdp83se
    Projector: sony vw60
    Screen: Da-Lite 106"
    APC S20 Power conditioner
  • comfortablycurt
    comfortablycurt Posts: 6,745
    edited March 2009
    I've been noticing a rattle coming from one of my 7A's lately. It only occurs when I have it really cranked up, like way above my normal listening level, or during really deep bass passages. I finally got around to tracking it down, and it turns out that one of the screw holes on the tweeter is stripped out.:(
    I don't really wanna fix it with the toothpick method, so I'm gonna have to pick up a hardwood dowel and fix it properly.:)
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
    edited March 2009
    I think an MRI would reveal the true cause as being a case of a loose nut operating your system:D:p
  • BrettT1
    BrettT1 Posts: 560
    edited March 2009
    My guess as to why he is THE PRES.
    :cool:
    edited March 2009
    That's why I said a "temporary fix". It'll getcha' by until.........
    Sometimes tunes are really that important. ;)
  • comfortablycurt
    edited March 2009
    treitz3 wrote: »
    I was thinking about doing that for a temporary fix, but it's not really noticeable 90% of the time. For the most part, I only ever hear it during movies, during really deep bass passages, when I have it cranked up louder than I usually do. I just heard it during music for the first time today. I was listening to "Come Together" by the Beatles, which starts off with a really deep bass line, as I'm sure most of you know.;) I had it cranked up way higher than I do during normal listening. Actually it was probably the highest I've ever had them turned up since getting them. It sounded great just FYI.:D
    I'm considering doing some XO mods, and adding some Moretite to all of the drivers later this year. I'll probably just fix it when I do that, rather than tearing it apart twice, since it's not really bothering me the majority of the time.
  • dagame27
    dagame27 Posts: 576
    edited March 2009
    Thanks for the advice guys. I tightened the other screws, as well as the crossover. It seems to be ok for now, but I will eventually have to fix the stripped screws. I figure that I'll do it the right way the 1st time so I don't have to do it again. Maybe it gives me an excuse to do some upgrades:D
  • dagame27
    dagame27 Posts: 576
    edited March 2009
    After hearing the rattle again during a movie tonight, I finally got to taking off the radiator. It turns out, it was just the internal wires hitting the back of the passive. A little tape and I'm all good to go:cool:
