How to use a sub in a 2 (.1) channel rig?
dbaldus
I've been considering getting into 2 channel for quite awhile now, but I just love my SVS PB12-Plus/2 sub and would hate to go without it for music as my mains are RTi70s. The problem that I have been having is that none of the 2 channel pres seem to have an output for a subwoofer, so I'm just wondering if there is a way to set up my 2.1 channel rig in a way that I could use my RTi70s and my SVS together?
Any suggestions would be much appreciated - thanks!
2-channel
Squeezebox Touch| MSB Analog DAC | Audio Research Ref 40 Anniversary Edition| Pass Labs X350.8 | Wilson Audio Sasha 2
Arcam AVR 550 | GoldenEar Triton One | GoldenEar SuperCenter XXL | GoldenEar Aon 3 | JL Audio Fathom F113v2
Post edited by dbaldus on
I think you could wire your sub using speaker cables from your speakers. Should be covered in your sub manual.Speakers: SDA-1C (most all the goodies)
What pre-amp or receiver are you using? I assume that you are going into the "Low Input" on your sub. I am not clear on how you are connecting but if your pre-amp has a single dedicated sub output then you may need to use a "Y-adapter" to split the signal and feed it into both "Low Inputs" (left and right) on the sub. Please provide more details.Stan
Main 2ch:
HT:
Other stuff:
Just buy the Rotel RC-1082, or 1070. They have two pair of RCA pre-outs.
CRESCENDOPOWER wrote: »Just buy the Rotel RC-1082, or 1070. They have two pair of RCA pre-outs.
The description says there are 2 pairs of unbalanced RCA outputs on both units, but the manual shows only one set on each unit.:eek:
