surround sound
Airplay355
this weekend i heard one of sonys home theater in a box systems, bottom line is that it sucked and hurt to listen to....it was a disgrace to all speakers ever made....one think i did notice however was that i could tell where the sound was coming from, if the surround speakers were playing a sound i knew it was from behind, same with the mains........is this a good thing in a system? or should you not be able to tell exactly where the sound is coming from........on my system you cant and i wanted to know if that was because my surround speakers ( yamaha) arent matched to my front sound stage (rti100s and a cs245i).
Post edited by Airplay355 on
Well...what I think is more important is, are all the speakers creating a soundfield together? I think that is the point of surround sound...Your question can be a veiled discussion about Dipole vs direct radiating...which can go on forever...
as far as your speakers are concerned, check the timbre rating of each...
Audio Physic Scorpio II
Pathos Logos
MIT Shotgun S3
Bada HD-22 CDP
