Does the Cord Matter?
OK...bottom line....Does the type of cord type matter that is driving my PSW111 SW? Right now I am using the cheapest cord and it sounds fine. I know I have read posts where people are buying $100 cords. What really is the difference? Is this a sound change that only my dog can hear?
Post edited by Evanguy2004 on
  • MikeC78
    MikeC78 Posts: 2,315
    edited March 2009
    Your current power cord is working just fine. I wouldn't worry about upgrading the cord, IMO.
    treitz3 Posts: 20,159
    edited March 2009
    I don't know if that sub you will be able to notice any change with but with 3 out of the 4 subs I have owned I have most definitely noticed a change for the better. Tighter bass, cleaner reproduction and you can feel the change as well as hear the change. The one sub I did not notice any change with was my first Polk sub that had an 80 watt plate amp. I forget the model # but I believe that it was the beginner sub [more like a mid-bass module]. The more you step up in sub quality IME, the more an upgraded PC can make a difference in the sound.
  • Conradicles
    Conradicles Posts: 6,388
    edited March 2009
    Where is a good place to buy an aftermarket Power Cord for a reasonable price?
  • Face
    Face Posts: 14,340
    edited March 2009
    http://signalcable.com/power_cables.html
    Mention Club Polk and you'll receive a 5% discount IIRC.
  • Conradicles
    edited March 2009
    Thanks Face. Excellent prices.
  • Face
    Face Posts: 14,340
    edited March 2009
    I'm a big fan of their "digital reference" PC and even use one on my DLP.
  • Conradicles
    edited March 2009
    It is great to see that "Made in the USA" label on those cables!!!
  • MikeC78
    edited March 2009
    Mention you are a CP member too, he'll give you a little discount.
  • Conradicles
    edited March 2009
    Which component would benefit the most from a Power Cord upgrade?
    The power amp or CD Player?
  • Erik Tracy
    Erik Tracy Posts: 4,673
    edited March 2009
    As Kosh would say...."yes".... :D
  • Face
    Face Posts: 14,340
    edited March 2009
    It depends. Some amps respond well, some don't at all...same for digital components.
  • TNRabbit
    TNRabbit Posts: 2,168
    edited March 2009
    ...only the umbilical cord...
    TNRabbit
    NO Polk Audio Equipment :eek:
    Sunfire TG-IV
    Ashly 1001 Active Crossover
    Rane PEQ-15 Parametric Equalizers x 2
    Sunfire Cinema Grand Signature Seven
    Carver AL-III Speakers
    Klipsch RT-12d Subwoofer
  • Mike21
    Mike21 Posts: 252
    edited March 2009
    +1 to MikeC78.
    If it ain't broke, don't fix it.
    If I can afford it after paying 2008 taxes:eek:, I'm buying the Signal Digital Reference for my computer.
    Other good value power cords at Zebra and Element.
    ____________________________________________
    Home Theater 32"LG LCD; Comcast; 7.1 Onkyo 805; Fronts: Polk M50s; Center: Polk CS2; Sides: Polk M40s; Rear: B&W LM1s; Subs: (2) Sony 12" x 100w; Samsung 1500BDP; Toshiba A-2 HD-DVDP.
    PC stereo: Viper custom PC: Windows XP; ASIO4ALL; JRiver Jukebox> Pop Pulse USB to S/PDIF conv> Monarchy DIP > Musiland MD10 DAC > Parasound 2100 pre> Aragon 4004 MKII amp> Dali Ikon6 towers; Sunfire True Sub; PSA Duet, Ultimate outlet and Noise Harvestors.
  • lovebohn
    lovebohn Posts: 3
    edited March 2009
    So your saying to buy a new 6' power cord to make your sub sound better? What about the other 50' of electrical wire from the panel to the outlet, nothing is changing there? I think you would have better luck buying a good RG6 coaxial interconnect cable to run from your receiver to the input on the sub, can't go wrong with a Canare/Belden setup from places such as Blue Jean Cables or other online guys.
    edited March 2009
    lovebohn wrote: »
    Yes. Depending upon the application, the type of sub and whether or not it responds well to it or not. There are no guarantees in audio. My best advice would be to try it.
    As far as the 50' of wire before the PC upgrade is concerned, just run a search and you will find a plethora of responses concerning that. Most change to a 20 amp line for improvements. Another thing you could do is run a search on Darknight's threads. He is very thorough in his writing and I will guarantee that you will learn a thing or two.
  • kneedragger37
    kneedragger37 Posts: 108
    edited March 2009
    lovebohn wrote: »
    One would hope that if you're spending the coin on reference-quality power cables, you have a high-quality power conditioner between said power cable and the run from the panel to the outlet. And as treitz mentioned, a listening room with acoustical treatments and audiophile equipment that would allow you to hear the benefits of such cabling would also likely have at least dedicated 20A circuits.
