LSi7 for Centre
jacob.simpson
Am using RX-v663 Can i use a pair of LSi7 Bookshelf connected in Series to get 8 ohm Load as a centre Channel, Am using R50 as Front and Fxi3 as Surrounds (additionally RM6800 as 5.1) Planning to Sell RM6800 and get a DSW MP1000, or if i get a Monitor 40 at good price, for Centre and connect in series it will be 16 ohm will it be too bad to connect it in series or will i damage the AVR with parallel connection which will presend 4 ohms load. I know am mixing up series here. Will the sound be very different with mix up of the series.
Post edited by jacob.simpson on
Bad idea. Use them as mains and if budget holds it, get a 2ch amp to power them.
Keep the front stage (L-R-C) speakers the same. You can probably get away with the FXi3's for surrounds. So decide on what you want to use as fronts and pick a center accordingly.
Your running 3 different types of speakers in your HT setup. I would pick one type you like and use those. As far as using LSI 7's for a center channel I did but I ran mine on a external amp.
