Apple Lossless Encoder
TheMARPATNinja7
I've been shuffling through different ripping options on my iTunes and I came across the Apple Lossless Encoder. It claims to retain most of the original sound quality without taking up the space of a WAV file. I've put a few lossless, WAV and Mp3 versions of the same song on my iPod and compared them and I can't tell too much a difference. Of course this is on my $20 headphones because I can't wake up the whole house comparing sound files (it will get the system test tomorrow). Can anyone tell me about the lossless format and if it is actually legit?
Post edited by TheMARPATNinja7 on
It's not surprising that you can't hear much of a difference through the iPod and $20 phones, as that combo is probably just not resolving enough.
Personally, I think that for "typical" portable use, a high bitrate mp3 is plenty good enough. By "typical", I mean that you are using a portable player with non-high-end phones or connected to a car's aux port. I use the Lame mp3 encoder at the highest quality VBR setting, which produces around 240 kbps bitrate.
Now, if you're using a nice dedicated headphone rig or using a nice DAC connected to a resolving audio system, the benefits of lossless or wav will become more apparent. Personally, I use flac lossless for these scenarios.5.1 and 2.0 ch Basement Media Room: Outlaw 975/Emotiva DC-1/Rotel RB-1582 MKII/Rotel RB-1552/Audiosource Amp 3/Polk LS90, CS400i, FX500i/Outlaw X-12, LFM-1/JVD DLA-HD250/Da-Lite 100" HCCV/Sony ES BDP/Sonos Connect. DC-1/RB-1582 MKII/Sonos Connect also feed Polk 7C in garage or Dayton IO655 on patio.
2.1 ch Basement Gym: Denon AVR-2807/Klipsch Forte I or NHT SB2/JBL SUB 550P x 2/Chromecast Audio.
2.0 ch Living Room: Rotel RX-1052/Emotiva DC-1/Klipsch RF-7 III/Sony ES BDP/LG 65" LED.
2.0 ch Semi-portable: Klipsch Powergate/NHT SB3/Chromecast Audio.
Kitchen: Sonos Play5. -
It's lossless. If you go from wav to ALAC and back to wav you end up with the same bits. If there's any loss from just sticking a CD in and letting iTunes do its thing in ALAC, it will be from the CD extraction. Shouldn't be a problem if you have a decent drive and an undamaged disc, but some people get anal about that step of the ripping process.
Gotcha, I've given it a go on my home rig and I'm noticing a slight difference in highs and a notable difference in the sub 100hz region. It's good for some songs but I'm not going to change my whole library over or anything.
SEH is correct. There should be NO difference from the source file because it keeps all the information intact. MP3 on the other hand, throws out information forever. FLAC is another lossless format.Slowly emerging from the 90's
Fronts: Polk LSi15's
Center: Polk CS350ls
Pre: Sony STRDA555ES
Amp: Rotel RMB-1075
Sub: Velodyne SPL-1000
TV: 46" Sharp Aquos LCD
Dust magnet: Sony PS3
