Questing regarding bi-amping
BjornB17
BjornB17 Posts: 752
edited March 2009 in Speakers
I'm using a UPA-7 to bi-amp my RTi10's. I have a question as to how the biamping works.
Obviously I am doing passive bi-amping as I am using the speaker's internal crossover. The electrical signal send through the wires to both sections of the speakers are obviously full range because there is nothing to filter out the low or high frequencies before they get to the speaker. With that in mind.... what happens to the lower frequency energy in the wire connected to the high frequency section of the speaker? Does the crossover dissipate it in the form of heat, or does the speaker just not draw energy in that frequency range?
Will bi-amping with 2 150 watt amp sections per speaker indeed yield a max power of 300 W per speaker, or will it still be a max of 150 W because the crossover is dissipating the unused electricity?
KEF Q150 | Rythmik F12 | Yamaha Aventage RX-A780
Post edited by BjornB17 on
    treitz3 Posts: 19,958
    edited February 2009
    ^^^excellent post^^^ ;)
  • hearingimpared
    hearingimpared Posts: 21,136
    Nice write up xcapri79!
  • BjornB17
    BjornB17 Posts: 752
    xcapri79 wrote: »
    Essentially the speaker will draw what "it needs". The total current draw actually depends on the impedance of the speaker itself, crossover, connecting wires and internal impedance of the amplifier. This represents the load as seen by the amplifier.
    The current drawn by the resistive component of this total impedance is dissipated in heat. Note that the impedance of the speaker is not a constant. It is dependent on the frequency. The impedance of the speaker will change depending on the frequencies available. This in turn affects the amount of current drawn by the speaker.
    The crossovers are filters. There are different types of filters that are "tuned" to pass a range of frequencies to a particular speaker.
    High frequencies are passed on to the tweeter, mid-range frequencies are passed on to the midrange speakers and the low frequencies are passed on to the woofer.
    How is this done? A highpass filter represents a high impedance to low and midrange frequencies and a low impedance to the high frequencies. So effectively only the high frequency current is passed on to the tweeter and the low and midrange frequencies are blocked not dissipated.
    The tweeter is a transducer that converts the electrical energy to mechanically vibrating sound energy. Not all of this electrical energy is converted into sound energy. Some of it is also converted into heat and air turbulence.
    The midrange and woofers and their respective filters work in a similar manner.
    Each type of speaker is designed to work properly within a specific frequency range. Actually, this applies to most electrical and mechanical system not just speakers. They are generally designed to work within a particular frequency range. Outside that range they often do not work very well.
    Bi-amping essentially narrows the frequency range that each amplifer needs to provide. The midrange/woofer with their lower impedance will still draw most of the current and the tweeter will generally draw a much smaller amount. Each amp in this case will generally not be generating an equal output. Does this help?
    Yes, thanks for the explanation!
  • comfortablycurt
    comfortablycurt Posts: 6,745
    x2 on that. Very nice post. That actually answered a few things I'd been wondering about myself.:)
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
  • TNRabbit
    TNRabbit Posts: 2,168
    Excellent post there.
    To add: The low frequency information going to the upper range speakers is converted to HEAT by the crossover components used for that section.
    The high frequency information going to the low range speaker(s) is also dissipated as heat in the crossover but there is much less energy to dissipate in the upper frequency.
    TNRabbit
    NO Polk Audio Equipment :eek:
    Sunfire TG-IV
    Ashly 1001 Active Crossover
    Rane PEQ-15 Parametric Equalizers x 2
    Sunfire Cinema Grand Signature Seven
    Carver AL-III Speakers
    Klipsch RT-12d Subwoofer
  • lumpy
    lumpy Posts: 113
    so - could biamping cook the crossover in the speaker?
    and what would be better:
    A. use one of the two amps in bridged mode for the right channel and the second amp in bridged for the left channel.
    or
    B. use one of the two amps for the high posts on the L/R speakers and the other amp for the low pass posts on the L/R speakers
    pop
    media room: Lsi25 mains driven by an audiosource amp300, LSi9's driven by another amp300, LsiC drivin by an audiosourcAmp200, Lsi7 rear channels driven by receiver - Yamaha 863, Panamax 5300, epson 6100 w/ 106" elite cinatension2 screen, HPz555 media center, oppo 980, techniques SLbd3 turntable,xbox and ps3,
    living room: VM30 mains driven by a niles 2125, VM20 center and VM10 surrounds, velodyne dsp10, yamaha rxv661, cambridge audio dvd89, panamax5300, philips 42" plasma
