turntable mat/pad
Toolfan66
Looking for a good turntable mat. Where can i buy one? looked on ebay but not sure what is a good one.
Post edited by Toolfan66 on
How come i i had a feeling you would be the first to chime in? LOL. i almost just PM'ed you first.
Thanks,
Larry. -
Thanks!!! does a record clamp really help?
Joe,
Do you have any experience with the carbon fiber and/or the Ringmat?Carl -
Joe,
No not at all. -
TOOLFORLIFEFAN wrote: »Thanks!!! does a record clamp really help?
Absolutely. A turntable should not be sold without one. You will be amazed at the improvement a record clamp makes over the sound without one. -
Joe,
Carl I am a matless believer.:eek: However, Rich uses a carbon fiber mat and swears by it. -
hearingimpared wrote: »Absolutely. A turntable should not be sold without one. You will be amazed at the improvement a record clamp makes over the sound without one.
Ditto that! Joe's clamp is the best!
CarlCarl -
hearingimpared wrote: »Carl I am a matless believer.
You like riding bareback eh?:eek:Carl -
I ordered one of these a couple days ago. Have you tried it?SDA-1C (full mods)
Carver TFM-55
NAD 1130 Pre-amp
The Clamp
Nakamichi CR7 Cassette Deck
Cambridge Audio DACmagic Plus
ADC Soundshaper 3 EQ
Ben's IC's
Nitty Gritty 1.5FI RCM -
Is it a clamp or just a weight? Newbe on the clamp. What clamp do you prefer? -
TOOLFORLIFEFAN wrote: »Is it a clamp or just a weight? Newbe on the clamp. What clamp do you prefer?
It's a record weight. Record weights are useless when trying to remove warps.
I recommend this clamp.
http://store.acousticsounds.com/browse_detail.cfm?Title_ID=36249
