Absolute beasts!!!!!!!
cam5860
cam5860 Posts: 632
edited February 2009 in Car Audio & Electronics
W0v2 Subwoofer Drivers are “Absolute Beasts” at moderate power levels in compact enclosures.
W0v2: Technologies
The term “overbuilt” gets thrown around a lot, but in the case of the W0v2's, it actually applies.
With beefy 2.0 or 2.5-inch voice coils and our patented Elevated Frame Cooling, they're certainly capable of handling power. They also offer best-in-class excursion capability, with motors refined using our exclusive DMA modeling system for increased output and better sound quality. In simple terms, when the going gets loud, the W0v2's are built to perform like no other woofers in their price class.
This powerful combination of performance, value and installation attributes make them the “go to” choice for those seeking high performance from an affordable subwoofer system. You simply won’t believe you’re listening to our least expensive subwoofer drivers!
Available Models:
10W0v2
12W0v2
15W0v2 (Available 2nd quarter, 2009)
DMA Optimized Motor System
Highly optimized motor system delivers linear motor force over a wide range of excursion and power levels to reduce distortion. more info...
Elevated Frame-Cooling
(U.S. Patent #6,219,431)
Creates a pathway for high-velocity air to flow directly across the top-plate and onto the voice coil. more info...
Most Real Excursion
in its Class
The W0v2's offer more linear excursion than our original W6 subwoofers, at less than half the price!
What does this mean for you?
- Louder Bass!
- Less Distortion!
Insanely Great Bass in Small Enclosures!
For maximum application flexibility, W0v2’s are designed for use in compact sealed or medium-size ported enclosures.
10W0v2: 0.65 cu.ft. sealed
12W0v2: 1.375 cu.ft. sealed
15W0v2: 1.75 cu.ft. sealed
The Story of "MO"
He's back after all these years... our iconic "bass-face" character first debuted in the original JL Audio Reference Manual to denote subwoofer systems capable of making you look just like him.
We make it easy to protect your investment.
W0v2's are designed to directly receive JL Audio's protective grille mesh inserts (sold separately). Ask your dealer or buy them here .
PURCHASING JL AUDIO PRODUCTS VIA THE INTERNET Search the Site
Copyright © 2009JL Audio, Inc. - All rights reserved. Become a Fan!
Post edited by cam5860 on
