No sub
Toolfan66
Toolfan66 Posts: 18,057
edited February 2009 in Electronics
The ONKYO DVD/SACD player has no sub on the multi channel when playing a SACD. i have PINK FLOYD DSOTM on sacd 5.1 when playing my sub it won't come on. i have all the RCA's hooked up. am i doing something wrong? i can't figure it out, i have gone into the receiver setup and all looks good, but i don't know. anybody else had this problem? it sounds great without it but would like to know what i am doing wrong.
Thanks,
Larry.
Post edited by Toolfan66 on
  • comfortablycurt
    comfortablycurt Posts: 6,745
    You might need to go into the audio options menu on the DVD player and manually turn the sub on. I had the same problem when I first hooked my Cambridge DVD89 up, trying to play the same CD.
    There should be an option somewhere in the menu to turn the sub on, I'm guessing that's your problem.
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
  • LessisNevermore
    LessisNevermore Posts: 1,519
    1. If all else fails....RTFM.
    2. Your receiver likely has independent memory settings for all inputs. Check the levels.
    3. See #1.:D
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    Are you using RCA from the source to the receiver or are you using a digital cable from the source to the receiver?
    RT1
    RT1
    I have the HDMI,OPTICAL OUTPUT,and RCA's hooked up.
