Will CS20 Center be timbre matched to Monitor 60's (T90e's)
nytoy98
nytoy98 Posts: 1
edited August 2010 in Speakers
I have a set of T90e's which are the same as the Monitor 60's. I have the OWM3 as surrounds and have been looking for a CS2 and am unable to find any online or locally in BLACK.
I know the CS10 and CS20 is for the Tsi series which I think I read is the new monitor series. Can I go with the CS20 and have it match nicely with the T90e's? Anyone done this? Thanks.
Post edited by nytoy98 on
  • Kchill
    Kchill Posts: 262
    edited February 2009
    I would say yes. Just a remodel of the original. Same speakers different cabnet.
    Retired Onkyo 520 (returned broken HK 247)
    Now a Pioneer 1018
    CSi3
    2- RTI10's
    2- R50's
    2- Fxi3's
    Onkyo 250W Sub
    Polk psw-10
    "Inch by inch lifes a cinch, yard by yard life is hard"
  • comfortablycurt
    comfortablycurt Posts: 6,745
    The TSi/CSi series speakers are basically just the newer version of the Monitor series. They're essentially the same speakers, so yes, you'll be fine using a CS20.
    Welcome to Club Polk.:)
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
  • wutadumsn23
    wutadumsn23 Posts: 3,702
    +1 time to beat a dead horse, lol. The TSi series is pretty much the same as the Monitor's, and will match nicely with what you have.
    HT Rig
    Receiver- Onkyo TX-SR806
    Mains- Polk Audio Monitor 70
    Center- Polk Audio CS2
    Surrounds- Polk Audio TSi 500's :D
    Sub- Polk Audio PSW125
    Blu-Ray- 80 GB PS3
    2 CH rig (in progress)
    It's not that I'm insensitive, I just don't care.. :D
  • kdog03
    kdog03 Posts: 13
    edited July 2010
    No way, had this setup...CS20 center channel is a bit more "smooth" accross bright end unlike the shrieks of the monitors. The TSI is more theater like than the monitors...Ive had a number of tests done with the monitors with various setups before settling on a choice.
    F: TSI 500
    C: CS 20
    S: OWM5
    R: OWM3
    SUB: Micropro 4000
    ONKYO 676 7.1 130\ch
  • BWilberg266
    BWilberg266 Posts: 191
    edited July 2010
    Sorry kdog, going to have to disagree as far as wether it will match. I'm running the CS20 with Monitor 70's for my front soundstage and I think it sounds great. And honestly the shrieks you speak of don't occur with my Denon 1910. If you have things set up right with the eq there should be no issues.
    I love my CS20/Monitor front...I say go for it
    Plus the question isn't if he should buy Monitor or TSI towers, it's if he should get the CS20 to add to his current towers. From what you're saying the CS20 will outperform his monitors, and since when is that a bad thing? If he is really that impressed by the sound of the CS20 over his current fronts then he just has something new to upgrade to ;)
    Main Setup
    Fronts - Energy RC-50's
    Center - Energy RC-LCR
    Rear - Energy RC-R's
    Subs - Gone...
    AVR - Pioneer SC-37
    Blu-Ray - Sony BDP-S360
    TV - Vizio E550I-B2
    Media Server - Mac Mini
  • moundas
    moundas Posts: 1
    edited August 2010
    I just bought the Polk Monitor 70 floor speakers and Polk Audio RC85i In-Wall Speakers. I also purchased new center channel. I ordered the Polk Audio CSI-A4 center channel because it was smaller in size to the CS20 center channel. Do you think they will work together or will I have a timbre match issue? Is there any way to adjust? Any help would be appreciated. Thanks.
